Old 07-27-2021, 05:17 PM #1
makokak makokak is offline
makokak is on a distinguished road
Hard Brake Pedal on or off engine barely have brake when its drive from stop.
Good Afternoon everyone,
My vehicle: 2000 4runner V6 4X2
recent change/upgrade: TBU in 2018.
oh oh oh my wife drove it for 3-4 miles while hand brake is engage.
Now: brake pedal is hard on or off engine, barely have brake when put to drive.
test done: remove the vacuum hose from intake manifold, vacuum is pretty strong, remove from the booster vacuum is pretty strong no leak along the vacuum hose.
what else could it possibly be? or any more test i could done?
makokak is offline   Reply With QuoteReply With Quote
Old 07-27-2021, 05:37 PM #2
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Probably the booster, I don’t think driving with the e brake on would cause this, I’d go to the junkyard and get a booster and see if that fixes it
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 07-27-2021, 05:42 PM #3
is it worth trying to see if it is the check valve, at least less than 10 buck from oreily's?
Old 07-27-2021, 07:01 PM #4
HiLife HiLife is offline
With the engine running to charge the vacuum booster. And then turning the engine off, you should have one or two vacuum assist pushes on the brake pedal if the brake booster and check valve are holding vacuum.
Old 07-27-2021, 07:08 PM #5
FunBobby's Avatar
FunBobby FunBobby is offline
FunBobby is on a distinguished road
FunBobby's Avatar
Mine did this last year, it was the booster
FunBobby is offline   Reply With QuoteReply With Quote
Old 07-27-2021, 09:52 PM #6
My check valve caused this on the 96
Old 07-27-2021, 11:42 PM #7
On mines, it was the booster that failed on the 4runner. It made driving interesting, made sure I had plenty room to brake.
My check valve was good but I replaced it anyway. Kept the older one as a spare.
I learned to drive on a 64 Malibu, manual drum brakes all 4 corners. That was a fun car to brake to a short stop.
Old 07-28-2021, 09:13 AM #8
Yea, my 68 Roadrunner was guess a lane on a hard stops.
Old 07-28-2021, 04:50 PM #9
Thank you guys for the reply.
i removed the check valve and mimic a vacuum and it does let the vacuum in but not going back in, i think thats how it should be.
i have new finding; while the engine is running i pressed the pedal probably a good 2-3" down and i can hear a hissing sound. does that confirmed my booster gone bad?
Old 07-28-2021, 06:47 PM #10
Buy the check valve and see if it solves your problem. If it doesn’t buy the brake booster and install your new check valve and your rig will rust out before you need to touch those two items again.
Old 07-29-2021, 11:27 AM #11
Doctorman Doctorman is offline
Doctorman is on a distinguished road
probably the booster...
do a nice brake fluid flush , if the pads are good you should be good
Doctorman is offline   Reply With QuoteReply With Quote
Old 07-29-2021, 01:09 PM #12
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Same issue I had a few years ago. Mine was the booster. I put on a used OEM one from a buddy's parts truck with half the miles mine had at the time and it was fixed.
Didn't have to open the brake system or anything. Just unbolted the master from the booster and moved it out of the way and the booster was a few bolts and it was off. Took like an hour.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 07-29-2021, 02:44 PM #13
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I also agree with the others that said it's most likely a bad brake booster. The video below was shot on a FZJ80 Land Cruiser but a lot of the information we share could help you swapping out the brake booster on your 3rd Gen. Good Luck!
Old 07-29-2021, 03:41 PM #14
TucsonMike TucsonMike is offline
TucsonMike is on a distinguished road
My 2000 and my friends 1998 both had a hissing noise and in both cases it was a bad booster. We both got the seiko booster which I believe is OEM . They r expensive $300 when I got mine several years ago. I bet your issue is the booster as well.
Good luck
MikeM
TucsonMike is offline   Reply With QuoteReply With Quote
Old 07-29-2021, 06:39 PM #15
Originally Posted by 19963.4lsr5 View Post
Yea, my 68 Roadrunner was guess a lane on a hard stops. k
I went through a couple intersections sideways locked up (in the rain, normally) in my '67 Ford truck with manual 4-wheel drums. The worst was driving after soccer practice with tired legs...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
brake , hard , remove , strong , vacuum
Hard Brake Pedal During Panic Stops - Brake Booster? Friday88 3rd gen T4Rs 24 Today 12:14 AM
Chasing a hard brake pedal issue jman11788 3rd gen T4Rs 6 03-26-2020 12:05 PM
Brake pedal hard to push down shoota 3rd gen T4Rs 40 04-23-2019 09:26 PM
Hard Brake Pedal? Brake Accumulator? beatadrum 4th Gen T4Rs 2 02-17-2018 12:33 AM
Brake pedal hard to push? jarnld Classic T4Rs 5 05-14-2008 12:59 PM
