No need to mess with it if you don't feel like it. The washer's job is to prevent a leak, which it's doing fine. I'm willing to bet there's at least a couple different options out there that fit and not just those from Toyota themselves
Originally Posted by gamefreakgc
I was under the impression that crush washers were better than flat in preventing leaks. That's why the fuel system only uses crush washers as gasoline is very thin and likes to leak.
Sounds correct to me - they're rounded on one side to crush into place and have a "perfect fit" in a way, which is also why they're not reusable
To that effect gear oil is a hell of a lot thicker than gasoline! It usually takes a pretty decent hole for gear oil to seep out anyways. No need to worry
Y2K Highlander
Millennium Silver 3.4L auto @ 320k and climbing
