Old 07-28-2021, 06:02 PM #1
danthemanx07 danthemanx07 is offline
danthemanx07 is on a distinguished road
Rear Axle Shaft Won’t Go All the Way In
SOLVED - Will leave for posterity. I was a little too timid. I tightened the hub nuts in a cross pattern and they pulled the shaft snug. No biggie.
I pulled my rear axle apart to get the seals in my ARB replaced. Reassembling things, I can’t get my passenger side axle to go all the way back in. It sticks out about half an inch.
I have read a few of the threads on here. Seems the culprits in other instances have been deformed splines on the shaft or an axle bearing not fully seated. My splines look fine and I didn’t touch the shaft bearing.
I did replace the oil seal, but it looks to be seated fully.
Anything I am missing or should I just give it a few taps with a deadblow mallet or tighten up the hub bolts evenly to pull it in?
2005 GX470
3.4l A340 Automatic to R150F Manual Transmission Swap
http://ttora.com/forum/showthread.php?t=159482
danthemanx07 is offline   Reply With QuoteReply With Quote
axle , bearing , rear , shaft , splines
5th gen rear axle shaft Ole Bones 5th gen T4Rs 15 01-22-2019 10:51 PM
HELP! Need Rear Axle Shaft Assembly rossgoldie 3rd gen T4Rs 0 09-03-2016 02:43 PM
WTB Rear axle shaft Toyotacolin 5th gen T4Rs 3 07-29-2016 12:53 PM
Rear Axle Shaft northernT4R 3rd gen T4Rs 10 10-23-2014 09:40 PM
