Old 07-29-2021, 09:34 PM #1
osideplayer osideplayer is offline
osideplayer will become famous soon enough osideplayer will become famous soon enough
Tow hitch cable/wires
I just bought this 4runner and noticed the tow hitch cable looked really rough. The cable goes to two different groups of wires. I traced the group of wires underneath the car to the engine bay where they were cut. I didn't try tracing the second group.
I'd like to tow in the near future so any suggestions would be appreciated. Im wondering if I need a new plug or if I should be concerned about the cut wires.
Tow hitch cable/wires-pxl_20210730_002152646~2-jpg  Tow hitch cable/wires-pxl_20210730_012006200-jpg
osideplayer is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 06:58 AM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
That was an aftermarket install, and they most likely had a trailer brake controller installed that was then removed in the sloppiest was possible.
Do you *NEED* a 7-pin for brake controller and 12v charging? If not, then you can either test what you have to see if it works (I'd rather you search this than tell you, or rather I'd rather you know you Can search this and Chose to search), or rip it all out and start again with a flat-4 (if that's what you need).
If this is all above you, pay someone else to sort it out for you.
Brian. is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 09:38 AM #3
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
As Brian. said if you don't need brakes then just install a Flat 4 connector.
You can buy a 3 to 2 wire non-powered adapter that you can connect to the left rear light.
Non-Powered 3-to-2-Wire Taillight Converter SKU #55178 for $17.63 by CURT Manufacturing
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 07-30-2021, 05:34 PM #4
Unless you need the brake controller, just get a new plug-n-play 4-flat harness from etrailer.com.
Remove all the old crap.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
cable , cut , hitch , tow , wires
2000 4runner a340f kickdown cable (tv cable) broken DPR64 3rd gen T4Rs 3 09-07-2021 02:28 PM
Running wires through hitch boot TerraCrawler 5th gen T4Rs 1 07-22-2017 08:59 PM
throttle valve cable/transmission kickdown cable stuck roll4life 3rd gen T4Rs 4 08-16-2016 02:03 PM
Spare tire cable bad, replace cable or carier? iBison 4th Gen T4Rs 10 06-16-2014 11:10 AM
Wtb: 2nd gen parking brake handle to wheel cable cable 541joseph Want to Buy/Trade 0 06-09-2014 11:22 PM
