Old 07-31-2021, 03:43 PM #1
fathousecat_ fathousecat_ is offline
fathousecat_ is on a distinguished road
Steering Question
Hello,
I have a question regarding steering. What would cause the feeling of a "deadness" in the steering wheel when traversing gravel? Over washboard especially it is noticeable. It is a feeling of disengagement. I have no other way of how to describe this. It is a '99 with 271k on odometer.
Thanks
fathousecat_ is offline   Reply With QuoteReply With Quote
Old 07-31-2021, 03:57 PM #2
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
The front wheels are bouncing up and down slightly so fast and they have much less weight on them.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 07-31-2021, 04:08 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Originally Posted by fathousecat_ View Post
Hello,
Thanks
Are you referring to understeer? I've noticed our vehicles have quite a bit of it at times, almost like there's a sort of sweet spot in the turning where it occurs most
Old 07-31-2021, 08:10 PM #4
I had been thinking of purchasing a new suspension parts. I am not looking for a lift. Stock height. Any suggestions?
Old 07-31-2021, 08:33 PM #5
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
How much money do you want to spend?
Brian. is offline   Reply With QuoteReply With Quote
Old 07-31-2021, 09:16 PM #6
Looking at 1.2k max. But I am open if given options I like.
Old 08-01-2021, 06:09 AM #7
Brian.'s Avatar
Brian.'s Avatar
If you're handy and willing to look, you can buy a set of Kings that need to be rebuilt for about that cost. No need to run the lift they're capable of. The upside is that you'd Never need to buy shocks again as they're rebuildable (replace the oil every other year).
If you want new and no fuss, then the Bilstein 6112/5160 combo is excellent. That's what I bought/run and I couldn't be happier... well, less cost would have made me happier, but as far as function goes I'm very pleased. Again, capable of lift but I'm running stock '99 height (plus or minus about a half inch). Their main benefit is a bigger body, which means more oil which translates to a little longer life and better performance over sustained rough conditions (washboards). I've punished mine with more than 30 miles of continuous washboards without any problem.
Below that you have a number of cheaper options that I know next to nothing about. A couple Bilstein options (5100/4100?), KYB gas-a-justs (which are supposed to be close to OEM for on-road performance) and a host of stuff no one talks about much on this forum.
Old 08-01-2021, 07:09 AM #8
Thanks for all the recommendations there! Looking at the Bilstein combo you recommended most seems to be best bet. Seems easy to install as well.
Old 08-02-2021, 06:40 PM #9
Just don't expect it to go away completely... there is just less grip on loose surfaces.
Oh, and run lower air pressure (if you have tires that will handle it correctly) to get much better comfort and grip off road. It allows the tires to conform to small road imperfections instead of bouncing over them. Obviously only worthwhile if you are going to be off road for a while and have access to a pump.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-03-2021, 01:54 PM #10
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Washboard is tricky no matter the suspension but obviously some are better than others. Shocks that provide a quicker rebound can help so you aren't 'floating' over the tops of each washboard section.
I also agree on airing down. I'm not much of an off-roader but I did buy a cheap set of speed bleeders and a simple air pump. It sits in the back of the truck. I can air down in about 5 minutes and air back up in about 10. If I need to get back on pavement I can still drive as I only air down to about 15 PSI. That's enough to still be fine on the road. It tuned my P rated Highway tires (yes, highway tires) into off-road beasts as I was getting less wheel slip than the guys with A/T tires with aggressive treads who did not air down.
326WHP 347TQ
271k , feeling , odometer , question , steering
'85 steering box question 88rnr Classic T4Rs 1 05-20-2018 09:17 PM
Steering question Cory619 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-17-2013 01:00 AM
2003 V8 90k Maint. Question + Steering Question zerowkul98 Maintenance/Detailing 1 10-21-2010 07:35 AM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
03 steering question, shootmymime 4th Gen T4Rs 2 08-17-2008 09:32 PM
