Old 11-13-2022, 08:30 PM #31
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by TimGFL View Post
I was able to get it running on starting spray at 1500rpm for 2-3 minutes, but now I've got bigger problems. Looks like I'm getting coolant from behind the timing cover. Guess it's time to do the timing belt, pulleys & water pump job and/or head gasket. With 280K+ miles (100K that I put on it), I guess it's earned it
If the head gasket leak is bad enough it could cause a very bad idle. White smoke says that the coolant is getting into the engine and burning off a a rapid rate. Water at idle will quench combustion and cause it to stall.
Bummer this is turning into a massive project but it is repairable.
326WHP 347TQ
fuel , gas , past , problem , rough
Rough Idle / Misfire after plugs and wires Gull81 3rd gen T4Rs 15 04-20-2020 05:27 PM
Upgrading Fuel System, Fuel Injectors, and Spark plugs! rhearne27 Engines / Suspension / Wheels / Tires / Audio / Accessories 7 03-26-2020 01:40 PM
plugs and wires? Suprareal General Discussions 2 01-07-2012 03:31 AM
Best plugs and wires? T?@\7 Classic T4Rs 10 12-31-2010 11:23 PM
98 T4R Plugs, Wires and Fuel Filter Betoseefu Maintenance/Detailing 4 08-22-2006 07:45 AM
