Old 08-01-2021, 11:24 AM #1
denvermaxd denvermaxd is offline
Real Name: Max
denvermaxd is on a distinguished road
Real Name: Max
Steering rack replacement - New rack orientation
I ordered a Toyota rack from a dealer, so it’s a brand new part.
Before I jacked up the front end and removed the old rack I had the steering wheel dead center and tied off, both wheels pointing straight down the road.
Now that I have the old rack off and can compare to the new rack, it appears the new rack is set to a hard left turn—the driver side boot is almost fully compressed, the passenger side boot fully extended.
On the old rack, both boots are about the same level of compression.
I’m afraid when I mount the new rack and attach the end links my wheels will be turned hard left but the steering wheel will be dead straight.
Is it standard for shipping the part that they set it to be not dead straight ahead?
Any tips on what I should do? I doubt I’ll be able to manually turn the intermediate shaft to bring it to a position matching the old rack.
2000 4Runner SR5 5-speed manual e-locker, 231mm Tundra brake upgrade, OME 881/890 Suspension, Stubbs Rock Sliders, TRD Supercharger
2022 Highlander
2002 Dodge Ram 1500
denvermaxd is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 12:20 PM #2
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
If you are not changing your outer tie rods you should be good. If you are, measure the length of your existing outer tie rods to the locking nut and start with that measurement on your new tie rods. Then jack up the front so the tires are a bit off the ground and hook things up.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 12:36 PM #3
HiLife HiLife is offline
That new rack came like that in a brand new box with seals unripped?
That IS strange. New racks, and rebuilt ones, are shipped dead center from my experience.
Old 08-01-2021, 02:46 PM #4
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
The OEM rack I installed earlier this year was shipped centered, but also had 2 different colored paint marks that lined up to show when it was centered. If your has those, get the tie rods where they appear more or less even and line up the paint marks.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 09:49 PM #5
bootown's Avatar
bootown bootown is offline
bootown is on a distinguished road
bootown's Avatar
I've done this a couple of times. I don't remember if they came centered or not from Toyota and I did it myself anyways. Kind of think one rack was centered and one was not. I probably used an adjustable wrench or vice grips to spin it left and right. Count the number of turns and you can use a tape measure too on the tie rod distance. I think it's ~7 full turns from lock to lock, so ~3.5 turns from lock to center.
bootown is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 10:05 PM #6
TravThePro's Avatar
TravThePro TravThePro is offline
Real Name: Travis
TravThePro is on a distinguished road
TravThePro's Avatar
Real Name: Travis
This is correct. ~7 turns total with ~3.5 being centered. All of the racks I have seen come directly from Toyota have come centered with a double paint line on them.
1996 T4R
TravThePro is offline   Reply With QuoteReply With Quote
dead , hard , rack , steering , straight
DIY: Steering Rack Replacement Xtremluck 5th gen T4Rs 36 05-29-2020 10:48 AM
Steering Rack Replacement Can't Get Lower Shaft Off Rack WoodenUnion 4th Gen T4Rs 1 09-27-2019 06:36 AM
Steering rack replacement: AAE or OEM? SpookyMulder 3rd gen T4Rs 15 02-12-2017 05:53 PM
Steering Rack Replacement NEKExplorer 3rd gen T4Rs 38 01-30-2016 06:19 AM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
