Old 08-01-2021, 01:02 PM #1
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
Steering Rack Question / Mystery Part
I am removing my steering rack and have been using @mbtim guide for this. The lines behind the steering rack below the rag joint have pretty rusted flare fittings. I bought the same flexi box end wrench Timmy has, but seems the flare nuts have been rounded a bit and the rust isn’t allowing them to budge. I put a lot of WD40 on them throughout the day and will be letting them soak for about a week. I don’t want to use a torch to heat them up and not sure how well vice grips would work. It also looks like the metal line that is closest to me is short, going into a rubber hose, so I am guessing once the rack is out, I could easily replace the metal part? The other line looks like it is permanently part of the whole assembly despite being part of a rubber hose based on how it looks like there is no gap in the hose or hose clamps. Any opinions on this?
The mystery part is on the passenger side fender well / frame. In replacing all of my suspension, the bracket holding a connector / electrical line just crumbled. Not sure what that is, but want to replace the bracket. Not interested in just zip tying it to the line above it.
Steering Rack Question / Mystery Part-a66ccce4-3624-4c04-8b58-20c5510ead3f-jpg  Steering Rack Question / Mystery Part-c79b4284-cdad-46fd-b502-3d4121c2705c-jpg
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 05:35 PM #2
HiLife HiLife is offline
Low pressure return line for the rack?
And, front passenger abs sensor connector?
Old 08-01-2021, 06:07 PM #3
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
Not related directly to post, but an oil/grease based anti-rust on that truck will extend its life like five-fold. Seems like in good shape for a truck that didn't receive any anti-rust, good thing you live in california.
You would not have to re-new it every year, even only once would help a lot. Would also get much less stuck bolts.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 07:13 PM #4
4x3Lander's Avatar
4x3Lander's Avatar
Yes, both lines have rusted square nut fittings. I need to figure out a way to get them unscrewed from the steering rack / replaced.
Perfect, thank you. I will see if I can find the bracket online and if not, will have to run to the junkyard.
Old 08-01-2021, 07:17 PM #5
4x3Lander's Avatar
4x3Lander's Avatar
Thanks. Previous owners didn’t really take care of the truck like I do, so rust won’t be an issue in the future. I do have cans of Fluid Film I can use for things like this and agree with you in using it. I have already removed all the rust you see in the picture and am continuing this removal as I am replacing all my front end suspension with new parts / paint. It is garage kept, in CA and not daily driven. Appreciate the feedback!
Old 08-01-2021, 09:21 PM #6
diverscale's Avatar
diverscale's Avatar
I used vice-grips for these on my totally nuts. Do you have the proper flare nut wrenches??? These could get it undone if not too rusty. Forget it if you are using standard wrenches. Search for flare nut wrenches.
Also, I don't even remember how it'S made back there and it's pretty late this sunday evening to go look at it... but for a stuck brake flare nut, I just cut the line and use a socket, then replace this part of the line. So if you are replacing the steering rack, that could be an option.
1998 4runner SR5
Old 08-01-2021, 11:40 PM #7
4x3Lander's Avatar
4x3Lander's Avatar
Yep, used the flare nut wrench that Timmy the Toolman recommended, hence why I was saying even with that, still didn’t work and seemed rounded a bit.
Yea, maybe if a pair of vise grips don’t work, I will just cut them like you mentioned and then replace those sections or entire line, depending.
Old 08-02-2021, 01:07 AM #8
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I'm thinking those are really your only two options. You could TRY hitting it with a heat gun, but it may not get it hot enough. Still might be better than nothing. It sounds like the PO took a spanner to it previously at some point
Old 08-02-2021, 01:51 AM #9
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
When I replaced my steering rack, we initially tried to remove that fitting on the car and failed. Even using a flare nut wrench, it rounded over. We disconnected the soft line and pulled the rack with that fitting still on. With the old rack on the ground with more room to work, we clamped a set of vice grips on the nut, heated around the outside of the fitting with a small propane torch, and then hit the vice grips with a 4 pound sledge and eventually broke it free. Once that was done, one of my friends reshaped the nut and we put it on the new rack and installed it. The bottom line is that even if the rack and fittings are original, that fitting is a pain to remove, and if I ever need to do a rack again I plan on buying a new fitting rather than dealing with removing it again.
Skulking is offline   Reply With QuoteReply With Quote
Old 08-03-2021, 10:52 PM #10
4x3Lander's Avatar
4x3Lander's Avatar
I will probably try the vise grips and / or cutting the line and then replacing it.
Yea, probably because I certainly didn’t. I didn’t spend almost $30 for a single 17MM flex box end wrench to try a regular wrench
Old 08-03-2021, 10:53 PM #11
4x3Lander's Avatar
4x3Lander's Avatar
Wow that sounds just as involved as mine will become. Thanks for the info and will see what happens!
Old 09-08-2021, 01:31 AM #12
4x3Lander's Avatar
4x3Lander's Avatar
OK, update on the two feed lines that run into the back of the steering rack. Despite two weeks of WD40 daily soaking, box end wrenches and vice grips, no such luck on removing them. SO, I had to cut the metal lines with a dremel.
Once I removed the rack, I used a 1/2” socket with a breaker bar AND an even longer metal pipe over the breaker bar and wow, got the box end fittings loose, but yea, no way those would have come off while still attached and in that tight space.
Anyway, now that those are off, trying to get the just as rusty rag joint off and I am sure it is not going to come off because of how bad it is rusted. I would rather just replace the component stamped 35031, but after some searching, it would make sense it is only part of the entire rack assembly.
Can anyone confirm this and / or have a part number if it can be purchased separately?
Steering Rack Question / Mystery Part-ab7c244c-0eaf-4641-9ad4-5d84b5ec273e-jpg  Steering Rack Question / Mystery Part-9ce8c255-0671-443b-a8d1-a48fc64c8f60-jpg
Old 09-08-2021, 09:38 AM #13
44022-35031
Old 09-08-2021, 09:47 AM #14
4x3Lander's Avatar
4x3Lander's Avatar
@HiLife wow, thanks so much!
That’s crazy. That piece is half the cost of an entire new rack. Hmmm, decisions, decisions.
Old 09-08-2021, 09:55 AM #15
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
If it makes a difference to you a new rack comes with both inner tie rod ends as well. Separately those are about $50 each. Just something to consider.
hose , line , part , rack , steering
2000 T4R Center Steering Rack Mounting Nut Part Number Bowtierebel 3rd gen T4Rs 0 03-22-2020 07:03 AM
OEM Steering rack...which part? jross20 3rd gen T4Rs 10 08-18-2019 11:12 PM
steering rack removal STUCK mid LCA replacement help + part# help macshemi57 3rd gen T4Rs 11 06-04-2015 12:28 AM
Steering Rack Guide Part Numbers...? A.Wilson013 3rd gen T4Rs 3 02-14-2012 06:04 PM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
