Old 09-08-2021, 10:20 AM #16
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
Originally Posted by Bad Luck View Post
If it makes a difference to you a new rack comes with both inner tie rod ends as well. Separately those are about $50 each. Just something to consider.
Yea I read that here on the forum a couple of times. It’s definitely enticing. My rack is fine, so I’ll have to decide what to do - try to get the rag joint off and hope the rust under it isn’t bad; wait around for a steering rack in a junkyard for that piece, as all 6 4Runners have no racks; or buy a new rack.
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 09-08-2021, 11:27 AM #17
spartacus's Avatar
spartacus's Avatar
Originally Posted by 4x3Lander View Post
OK, update on the two feed lines that run into the back of the steering rack. Despite two weeks of WD40 daily soaking, box end wrenches and vice grips, no such luck on removing them. SO, I had to cut the metal lines with a dremel.
Once I removed the rack, I used a 1/2” socket with a breaker bar AND an even longer metal pipe over the breaker bar and wow, got the box end fittings loose, but yea, no way those would have come off while still attached and in that tight space.
Anyway, now that those are off, trying to get the just as rusty rag joint off and I am sure it is not going to come off because of how bad it is rusted. I would rather just replace the component stamped 35031, but after some searching, it would make sense it is only part of the entire rack assembly.
Can anyone confirm this and / or have a part number if it can be purchased separately?
It's the gear assembly but toyota doesn't sell it separately . It's part of the rack and pinion assembly.
Old 09-10-2021, 10:13 PM #18
4x3Lander's Avatar
4x3Lander's Avatar
Actually @HiLife provided this part number - 44022-35031 and it costs about $225.
Going to see if I can get the rag joint off that part and if not, will have to hit the junkyards to get it, if even possible.
hose , line , part , rack , steering
2000 T4R Center Steering Rack Mounting Nut Part Number Bowtierebel 3rd gen T4Rs 0 03-22-2020 07:03 AM
OEM Steering rack...which part? jross20 3rd gen T4Rs 10 08-18-2019 11:12 PM
steering rack removal STUCK mid LCA replacement help + part# help macshemi57 3rd gen T4Rs 11 06-04-2015 12:28 AM
Steering Rack Guide Part Numbers...? A.Wilson013 3rd gen T4Rs 3 02-14-2012 06:04 PM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
