Old 08-01-2021, 09:43 PM #1
keeperofgoal keeperofgoal is offline
keeperofgoal is on a distinguished road
Truck Wont Start
I got a 97 SR5 V6 daily driver. today i went out in the morning eveything was fine. came home did some stuff for a few hours was going back out and she wouldnt start. I had no power to anything. hooked up the jump starter had power to everything (lights ac locks etc) but just fast clicking when trying to crank. i thought starter but when i take off the jump starter i have no power at all to anything and my charger/jump starter says fully charged. Is the battery bad? Can a starter just go bad all of a sudden with no symptoms? any help is appreciated!
keeperofgoal is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 09:51 PM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
My bet is a dead battery and a weak jump box.
Skulking is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 09:57 PM #3
TravThePro's Avatar
TravThePro TravThePro is offline
Real Name: Travis
TravThePro is on a distinguished road
TravThePro's Avatar
Real Name: Travis
How old/what quality is the battery?
Is there corrosion on the battery cables?
Is the alternator charge cable tight?
Is the main power wire going to the starter tight?
Generally, clicking happens with a lack of a strong enough current. A bad battery is normally the cause of this, but I have seen bad starters do this as well.
1996 T4R
TravThePro is offline   Reply With QuoteReply With Quote
Old 08-01-2021, 10:30 PM #4
yeah my jumper is ancient but it usually works for me
5 month old interstate mtp battery (i sell tons of these at my work and they do go bad now and then)
battery connections are pretty clean
both alternator and starter connections are tight
its just weird this happened so suddenly with no symptoms or intermittent issues. also that when i take the jumper off that it has no power i cant even get it. to click or do anything
Old 08-01-2021, 10:39 PM #5
Try jumping off another car, while it is running if necessary. Your jump box may be okay for a low battery, but what you are describing is a completely dead battery, and the jump box may not have enough power for that.
Old 08-01-2021, 11:00 PM #6
TravThePro's Avatar
Real Name: Travis
TravThePro's Avatar
Real Name: Travis
What is the voltage on the battery? What does it drop to with a load test?
This also sounds like a dead battery to me.
1996 T4R
Old 08-01-2021, 11:22 PM #7
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
Whack the battery terminal connection with a hammer
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 08-02-2021, 07:50 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Either a battery, or a major short.
I have seen new batteries blow a cell and go instantly bad. Kinda rare but can happen.
Old 08-02-2021, 06:00 PM #9
Me too. It was fine starting it and driving to my destination and went out to go home and not even a klick.
Old 08-02-2021, 06:26 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
exact same thing to Me.. Bat voltage went to 10v or so.
Old 08-02-2021, 06:41 PM #11
Could also just be bad terminals or corrosion on them. Happened to me recently on a <1 year old battery (but original terminals).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-02-2021, 07:48 PM #12
HiLife HiLife is offline
Happened to me last Thurs.
Been monitoring battery voltage since I been seeing the battery sides expand. Cells shorting out because of very bad roads, high temps are the killers on my batteries. I noticed voltages at the terminals went from 12.64, to 12.40 then 12.20 in about 3 weeks. Till all I got was a click when I turned the key last thurs.
Luckily I was prepared with a new battery on the side and changed the old.
Then changed out the terminal yesterday when I got a click again last Saturday. New bat voltage was still at 12.64 at the post. Wiggled the pos cable at it started.
All good so far new bat and new pos terminal.
Old 08-03-2021, 08:18 AM #13
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
I would check your ground connections also. A bad or loose ground will have the same effect as a dead/weak battery.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 08-03-2021, 12:36 PM #14
Thank you for all the replies!
so it was a completely dead battery due to a bad draw from my aftermarket head unit (from PO). i gutted it and all the shit wiring and installed a factory radio i had lying around then charged up a battery i had lying around that i knew was good and away i was.
bad , jump , power , start , starter
need help! truck wont start Trigle 4th Gen T4Rs 8 02-22-2020 10:39 AM
Truck sometimes wont start...starter contacts? zoombyu86 3rd gen T4Rs 22 04-15-2017 07:45 PM
1997 SR5 4x4 wont let my truck start 4Runnermex 3rd gen T4Rs 14 10-27-2015 10:18 PM
accelerator stopped responding now truck wont even start Woza2003 4th Gen T4Rs 8 07-11-2015 12:33 AM
Truck wont start after brush wire swap rewind206 Classic T4Rs 8 05-19-2013 07:42 PM
