Old 08-07-2021, 10:25 AM #1
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Rear trunk won’t open!
Hello fellow old members and new members. Been a while since I been on here let alone posted something. Life has gotten the best of me! I’ve barley been driving the 4runner ! But I still whip it once in a while. With that said, I’ve always had a issue with my trunk latch. It was always hard to open it from the outside. And now all of sudden. It won’t budge. It’s hard to say if it is even unlocking! I have a storage box back there. So there’s somewhat limited space but not to much. Any ideas? Open the back window and rip apart the plastic ?
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 08-07-2021, 11:28 AM #2
HiLife HiLife is offline
The storage box might be pushing against the hatch, not allowing the latch to unlock from the striker. In my case, this happened to me before.
I think it's a bad design.
Try pushing the hatch in while unlocking. It would relieve the stress on the latch being hung up on the striker, and hopefully it will unlock.
Old 08-07-2021, 01:06 PM #3
davidch davidch is offline
davidch will become famous soon enough
My experience has been that if the rear window is all the way up - and I do mean all the way - its drive motor is powerful enough to distort the rear hatch, or something therein, by just a little bit. It's enough so that it causes the hatch's release handle not to engage its mechanism properly.
I have found that if I lower the the window just a smidgen, the distortion eases and the release handle properly engages.
This has been more prevalent in cold weather.
At any rate, this costs nothing to try.
davidch is offline   Reply With QuoteReply With Quote
Old 08-08-2021, 06:24 PM #4
5th4runner 5th4runner is offline
5th4runner is on a distinguished road
On my '02 the carpet can slide back and jam under the hatch. This jams the release because when it finally shuts all the way it is really tight. It requires thumping the hatch closed whilst pulling on the hatch. The other issue is that after awhile the hatch release mechanism gets rusty and sticks such that the mechanism doesn't work. This requires a bit of cleaning and greasing. An interesting feature is that the rear wiper won't work if the window is open just a smidge.
Hope this helps.
and no
5th4runner doesn't mean 5th gen.
5th4runner is offline   Reply With QuoteReply With Quote
Old 08-09-2021, 03:22 PM #5
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
Fought with that all the way through Baja. Not a nice feeling when you can't open the back for the Federales at the military check points, luckily i worked easier at those time. There were a few times I couldn't get it to budge at all and with storage drawers it wasn't good. Back home here in Seattle, haven't had a problem with it at all. Have no idea why but it's smooth as silk and unlatches easily everytime.
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 08-09-2021, 04:11 PM #6
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
I had an issue with the back handle. One of the nuts that held on the latch bracket came off and the handle became completely disconnected from the rods and cables that make up the latch release. This meant that not even the key could open the back. Before it gave out it felt as if the latch would only open at the very last moment when you pulled the handle, which sounds like what it was with you.
I had to remove the back plastic panel, another metal panel that covers the window mechanism, and then reach around the back power window mechanism to put this nut back on and reattach the bracket. It was a complete pain in the ass, and I cracked the plastic panel because the clips were hella stubborn. It doesn't require specialized tools, but it is a big pain in the ass removing the plastic panel. Once you reattach the nut and bracket it will work again.
Pyral is offline   Reply With QuoteReply With Quote
Old 09-06-2021, 10:39 AM #7
I’ll try some of your suggestions. My storage box is tied dow. Sits behind the plastic trim. And the drawers have latches so it won’t open. Appreciate your replies all.
Old 09-06-2021, 12:36 PM #8
chickenman9102's Avatar
chickenman9102 chickenman9102 is offline
Real Name: Nick
chickenman9102 is on a distinguished road
Real Name: Nick
I purchased my runner a week ago and had the latch not work within an hour of owning the vehicle. Turns out the actuator wasn't initiating at all which was disallowing the hatch to open or close. Sort of silly that they use the fancy actuator on these old things...
Anyways, before taking apart the door panel I simply disconnected the battery, waited 5 minutes, reconnected the battery, turned the truck on, and my actuator worked again.
Maybe worth a shot? Good luck.
2004 4Runner V6 SR5 4x4 // 208k Miles
Rippin' Lips & Takin' Sips
chickenman9102 is offline   Reply With QuoteReply With Quote
back , hard , i’ve , open , trunk
HELP: How do I manually open my 2003 4Runner Trunk? rmajoran 4th Gen T4Rs 21 08-13-2020 01:31 PM
U.S. Trunk Liners. Best Trunk Liner for Dogs alext72888 5th gen T4Rs 5 03-12-2017 05:01 PM
How to open the trunk on a 1990 4runner. Mattyv10 Classic T4Rs 6 01-01-2014 08:18 PM
1995 sr5 trunk wont open contradan Problems & Warranty Issues 3 09-07-2012 10:18 AM
Trunk won't open rav1974 4th Gen T4Rs 7 12-25-2009 05:58 PM
