Old 08-10-2021, 10:53 AM #1
ir0nma1den ir0nma1den is offline
ir0nma1den is on a distinguished road
Shop didn't seat the rear spring properly - big deal?
I redid the entire front and rear suspension on my 4runner only to find out that the cheap Moog rear's I installed couldn't handle any amount of load while traveling. I ponied up for a set of OME 906's and had a shop install them. The drivers side was seated properly where the end of the spring meets the little groove on the axel seat, but the passenger side spring is not seated correctly. I've driven ~600 miles on it and it feels fine, but it's annoying that I know it wasn't installed correctly. I don't have my tools with me so I'll have to find a shop. Is this an issue that I should fix sooner than later? I just don't want to damage the spring.
ir0nma1den is offline   Reply With QuoteReply With Quote
Old 08-10-2021, 11:32 AM #2
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
This isn’t a huge deal in the interim as long as you’re not flexing it out on a trail, otherwise you could drop the coil spring easier since it’s not seated. It is something that needs to be corrected sooner than later though. Can you take it back to that shop to have them fix their error, or are you on a road trip? It’s a pretty quick fix for anyone with a floor jack.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 08-10-2021, 11:52 AM #3
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Would it be possible for you to post photos of the correct side and the incorrect side? I want to double check mine…
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 08-10-2021, 12:53 PM #4
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
You should be able to jack up the back of the truck by the frame on offending side and rotate the spring by hand to seat the termination of the coil in its seat, no biggy, no damage will have been caused and over time may even seat its self just by suspension cycling.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 04-14-2023, 06:23 PM #5
drewdo drewdo is offline
drewdo is on a distinguished road
Is my rear coil spring seated properly?
I just had Icon overland 3" rear springs installed, is my rear coil seated properly? I was told it should be flush to the notch, but its not exactly flush. Good enough?
drewdo is offline   Reply With QuoteReply With Quote
Old 04-14-2023, 08:43 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Photo of the coil and plate?
Old 04-14-2023, 09:31 PM #7
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
I agree with @brillo_76 for pictures. But honestly you should be able to get in there and turn it by hand if need be. Lift it up, tire off and get in there. I had to do that recently but it wasn't difficult at all.
Sent from my SM-S908U using Tapatalk
correctly , find , installed , shop , spring
**Rear Coil Spring Discussion - The Perfect 3rd Gen Rear Spring** rickashay 3rd gen T4Rs 344 03-27-2024 03:53 PM
Replacing stock shocks with 4600's, spring is not aligning properly salgood 3rd gen T4Rs 2 07-25-2016 01:10 AM
Rear upper spring seat measurement angus 3rd gen T4Rs 3 05-05-2015 08:52 PM
WTB: 3rd Gen Rear Spring Seat Roguestatus1688 For Sale: Suspension/Wheels/Tires 7 02-24-2015 09:08 PM
Help! Rear FJ spring won't seat! Morphyne 4th Gen T4Rs 9 12-02-2013 01:39 AM
