That might be the case for Single outlet crossover pipe found on Cali emissions, and 01-02 4R, but the Fed emissions 4R and older taco usually have 2 pipe flange that "y" at the down pipe (not the crossover pipe), I've seen them on older 1G taco's and appear to be this exact same part linked below, I'm not worried about adapting the downpipe to the cat, just wondering if the 2 pipe flange is the same. Link of current FED downpipe on the 4R. I'm pretty close to rolling the dice that they are a match, I find I highly unlikely the early Fed emission Taco and early Fed emission 4R have different crossover pipe flanges. But you never know since the JDM gas Hilux crossover pipe goes under the trans, not over the bellhousing like USDM 4R's..
1996-2000 Toyota 4Runner Converter & Pipe 17401-75100 | Toyota Parts Center
