Old 01-21-2022, 01:43 PM #46
Endlessblockades's Avatar
Endlessblockades Endlessblockades is online now
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Originally Posted by jbtvt View Post
Any hidden on/off switch for something required to start would do it. Fuel pump seems to be most common although can be easier to access and therefore bypass than some circuits. I read about one guy who had a fuel kill switch and his 4runner was still stolen, want to say it happened while he was shopping even. Other option would be starter relay wire, park/neutral switch, clutch switch, or you can just pull the efu or starter relay
Thank you! Another forum member have me a couple of good ideas, too.
Endlessblockades is online now   Reply With QuoteReply With Quote
Old 01-21-2022, 03:19 PM #47
willyd520's Avatar
willyd520 willyd520 is offline
willyd520 will become famous soon enough
willyd520's Avatar
Make sure you get a good kill switch wired in. Wouldn't want to lose it after all this!
I've got the best theft prevention in the world - it's a manual!!
willyd520 is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 07:18 PM #48
MasterFoo MasterFoo is offline
MasterFoo will become famous soon enough
This is awesome!
MasterFoo is offline   Reply With QuoteReply With Quote
Old 03-22-2022, 01:49 PM #49
willyd520's Avatar
willyd520's Avatar
Haven't done much to the old Runner since I got the front end sorted out. I ended up replacing the Cragar steel wheels with a set of used Pro Comp alloys - just didn't like the way they looked.
I also installed a Scangauge II with a Spiker Engineering mount to help monitor the coolant temp and voltage which I would honestly recommend to anybody. It's a tad on the expensive side but I've found it to be very reliable and an excellent scan tool if any check engine codes come up.
In bigger news, I just completed a two day trip up to Flagstaff with a bunch of other rigs and had an awesome time! Camped the first night in the Cinders OHV area which is northeast of Flagstaff.
Then we hit the highway to camp off of the Colorado River at the end of Diamond Creek Road - in the Grand Canyon!
Old 04-11-2022, 01:10 PM #50
willyd520's Avatar
willyd520's Avatar
On my way up to the Grand Canyon a few weeks ago - my A/C stopped working right outside of Phoenix. I was finally able to set some time aside to diagnose it and fix it this weekend.
Hooked up my new A/C gauges and the high side reading was unbelievably high – hanging around 400 PSI. Normal operation should be around 150-250 so this indicated I either had a blockage in the system or my expansion valve had failed. Given the fact that my A/C was intermittent beforehand I had a sneaking suspicion that my expansion valve had failed.
Ultimately though, at 234k miles I decided to buy once cry once and get the whole system replaced. I bought a new Denso compressor, condenser & expansion valve along with a Dayco Idler pulley, A/C Delco Drier & a Murray evaporator. (Would’ve gone Denso on both of these but was short on time). Started disassembly on Saturday morning and would’ve been done that day had Amazon delivered my compressor on time. Nonetheless I got it on Sunday and wrapped it up. Here’s a few pics documenting my install:
Pulling the evaporator:
Man that thing was gross! Good thing I was replacing it anyway. Here's the failed expansion valve, along with the rusty bolts connecting it to the evaporator. I cleaned them up with a wire wheel before installing.
New condenser & drier
I don't have any pictures of installing the compressor, but I found it really easy to remove. Everywhere I read online said you should remove the PS pump to get to it. I'm happy to report that you do NOT have to remove the PS pump! Disconnect your transmission cooling lines (don't have any since I have a manual) and remove the two 12mm bolts holding the power steering hard lines in place. Once you've done that the compressor can come right out the bottom. This made the removal/install much easier.
All in all the job was not very difficult at all and the results are fantastic - my truck now has a alternative use as a freezer.
Old 04-26-2022, 12:06 PM #51
willyd520's Avatar
willyd520's Avatar
Now that the A/C is buttoned up I'm starting to focus my efforts on the interior again. The old leather steering wheel has been disintegrating from the sun long before I sold it and it was time to get it replaced. Definitely feels weird having a new one on there but way overdue!
Before:
After:
It feels like a brand new car again! I still need to buy a new middle console lid (which is still available from Toyota) and some new center air vents as one of mine is busted.
Old 04-26-2022, 12:32 PM #52
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Before:
Was it brand new or just new to you from another 4Runner? I wasn't aware that steering wheels were still available as a replacement part from Toyota. If it was, could I ask what the cost was?
326WHP 347TQ
Old 04-26-2022, 02:26 PM #53
willyd520's Avatar
willyd520's Avatar
It was new to me! Unfortunately Toyota has long discontinued OEM steering wheels.
I've been looking for a nice leather wrapped wheel for a while, finally found this one on eBay and got it for $80.
Old 04-26-2022, 04:21 PM #54
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Whoa, I feel like I just read the same on another posts forum lol
I've become fond of wrapping the stock steering wheel if it's not chewed up already myself. A leather wrap and lace kit on Amazon is like $10 and honestly looks and feels great.
There are OEM type wrap kits from Japan that cost closer to $100 and are more work if you want the factory lol and feel. I've gotten used to the thicker, DIY wrapped wheel.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 04-27-2022, 05:33 PM #55
willyd520's Avatar
willyd520's Avatar
You got to live the reunion in real world time!! Even though the other post has way more info.
I'm keeping my OEM wheel in case I decide to have it re-done down the road! I've already removed almost all of the leather so she's ready to roll.
Old 04-28-2022, 08:33 AM #56
audiness's Avatar
audiness audiness is offline
audiness will become famous soon enough
audiness's Avatar
where did you get your steering wheel redone?
audiness is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 11:05 AM #57
The Amazon wraps go over the leather...
Old 05-05-2022, 05:07 PM #58
willyd520's Avatar
willyd520's Avatar
Bought the Marlin short shifter kit last week and got it installed:
Loved the way it shifted but absolutely hated how much taller the shifter was
So I took it to a machine shop and got it cut back down to factory size and now it's perfect!
Old 05-05-2022, 08:53 PM #59
Nice. What does the shifter kit do for a person?
I'm expecting my 1-in body lift will shorten my shifter for me without a machine shop
Old 03-21-2024, 04:05 PM #60
willyd520's Avatar
willyd520's Avatar
Sorry for the late reply on this, better late than never I guess lol.
I can shift faster and the shifts feel much notchier and firm. Well worth the investment IMO.
4runner , car , forum , pictures , sr5
Anyone recognize this? FLY_FISHING 5th gen T4Rs 14 08-03-2020 06:58 AM
Recognize this '07 T4R? Land Shark 1971 General Discussions 0 11-17-2014 04:10 PM
Anyone recognize this 4runner? SoCalAlan 4th Gen T4Rs 14 07-05-2012 03:15 PM
Anybody recognize this 4runner? 02adventurer 3rd gen T4Rs 7 12-03-2011 04:22 AM
