Old 08-12-2021, 05:35 PM #1
judoant's Avatar
judoant judoant is offline
judoant is on a distinguished road
judoant's Avatar
AC not very cold
My AC is blowing 68 degrees on a 90 degree day and has been doing so for years. Today i finally bought an AC Pro recharge kit. With the car running and on full AC the gauge reads in the green.
For the past couple of years the compressor would squeal a real quick every-time it kicked on.
Whats next?
Thanks
99 4 Runner Limited. 3" Toytec Ultimate lift with SuperFlex rear coils. 231mm Tundra calipers. Rear diff breather extension. 285/75-16 Nitto Trail Grapplers. Savage full skids & sliders w/ kickout. ISR mod. LED gauges. Shrockworks front plate bumper w/ loop. 4xInnovations rear plate bumper.
judoant is offline   Reply With QuoteReply With Quote
Old 08-12-2021, 05:41 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Whats next?
Thanks
Sounds like a loose/worn/glazed ac compressor belt for your noise. I can only guess on the temperature drop without knowing low side/high side pressures, ambient temp and humidity. Could be a weak compressor or it could be normal for temperature AND humidity.
Old 08-12-2021, 05:45 PM #3
judoant's Avatar
judoant's Avatar
Its 91 and 54% humidity today. I have no way to determine pressure numbers with the tools i currently have. I don't know what I would need for that or if i could even get access.
Every other newer car I am in blows much colder then mine. I was under the impression it should blow somewhere around 40 degrees regardless.
Old 08-12-2021, 06:05 PM #4
azrex azrex is offline
azrex is on a distinguished road
You can borrow (rent) a gauge set from Autozone. The gauges on those cans are notoriously inaccurate.
In the automotive world, 40 degrees below ambient is considered acceptable. There can also be a noticeable difference in vehicles, even if they're the same make and model.
Is it colder when you're moving verses sitting at a light?
The heater valve is completely closed?
The ductwork under the dash is intact?
azrex is offline   Reply With QuoteReply With Quote
Old 08-13-2021, 11:01 AM #5
Real Name: Patrick
Real Name: Patrick
It all depends on ambient temps and humidity. Also, you should be checking pressures with the windows down, ac on, set as cold as possible, blower motor on high, recirculate on, vehicle in park and at 1500 rpm's. Azrex is correct, 40 degrees temperature drop is good. Modern vehicles have more electronics to assist the ac system as well as more efficient compressors/condensers/evaporator.
Old 08-13-2021, 11:08 AM #6
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Like others said should be 40 cooler inside car.
If you want to do it right rent the a/c gauges from autozone or orielly( I bought a kit for $100 on amazon) or something and drain/ refill yourself. I replaced my condensor and drier and then I followed chris fix video for refilling and it was surprissingly easy. People are very wrong when they always saying take to ac professional, anyone can work on a/c trust me.
How to Properly Recharge Your AC System - YouTube
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 08-13-2021, 12:03 PM #7
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
That's true for the parts replacement aspect, but you're crapping up the environment if you're just letting refrigerant loose and not recapturing it. *THAT* is what a Pro can offer that's just not feasible for the home DIYer ($1000 entry cost). Thankfully most shops will Happily recapture anything in the system, you do the work, and you can either let them fill or spend a little more and fill yourself.
Don't be *That Guy* who just vents refrigerant to the atmosphere. Be better than *That Guy*.... *That Guy* is a dick.
Brian. is offline   Reply With QuoteReply With Quote
Old 08-14-2021, 08:52 AM #8
judoant's Avatar
judoant's Avatar
It is much cooler when the car is moving.
Duct work seems good.
Not sure about the heater valve.
Old 08-23-2021, 01:10 PM #9
That speaks to airflow through the condenser.
Check for dirt or debris clogging the fins and check the fan clutch for proper operation.
Old 08-23-2021, 01:13 PM #10
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
I just posted a video in the Maintenance Videos thread. This goes through recharging everything on the last half. You wouldn't need to test the vacuum or anything, but it's really simple if you rent the gauges (or buy them for <$50).
weekendclimber is offline   Reply With QuoteReply With Quote
Old 08-24-2021, 09:05 AM #11
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
/\ /\ /\ Hear, hear! I bought a vacuum pump and manifold gauge set, and a big tank of R134A, but all I'd ever do with that is work on systems that are already empty (converted a few empty old R12 systems, fixed a couple of R134a systems that had leaked out) but the thing I can NOT do is safely empty a pressurized system.
In that situation, take it by the local A/C shop and have them drain it. Then work on it. Then take it back and have them recharge it (since they charge for a drain/fill, and they're not charging for the R134a they extracted for the system). It was about $70 for that.
JohnMc is offline   Reply With QuoteReply With Quote
car , full , past , running , years
Cold and hot air kiltman Problems & Warranty Issues 0 01-16-2014 08:41 PM
AC is cold but not ice cold. Auce 3rd gen T4Rs 8 05-21-2013 11:03 PM
It's Cold Here jpalaska 4th Gen T4Rs 5 01-09-2007 10:03 AM
How cold should the AC be? Bluto Problems & Warranty Issues 15 08-10-2006 08:16 PM
does MPG go down in the cold? live4swell 4th Gen T4Rs 14 01-23-2004 03:37 PM
