Old 08-15-2021, 05:31 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Does the 3rz-fe have any common oil leaks?
I've had an oil leak ever since I bought my 4runner over a year ago, and now its becoming a more irritating issue now that I've fixed the larger ones. I always have oil pooling on my skid plate, its caused me unknowingly drive with low oil, the sump pan is always greasy, and the front of the engine had a centimeter layer of crudoil on it that actually noticeably impacted my engine temperature after I removed it.
I first thought that it was the bead of RTV sealant that held the sump pan onto the block, but a mechanic who specialized in Toyotas said that rarely leaks and is quite strong.
My next guess is the oil filter housing that has an oil cooler tacked on. Are there any common areas that leak on these engine?
Pyral is offline   Reply With QuoteReply With Quote
Old 08-15-2021, 06:20 PM #2
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Leaks I have addressed on my 3RZ:
Oil cooler gaskets
Oil pan gasket
Front main seal
Valve cover gasket
None were leaking badly but certainly seeping after 250k
JZiggy is offline   Reply With QuoteReply With Quote
Old 08-16-2021, 02:03 AM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Oil pressure sender started leaking on mine.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 08-17-2021, 01:47 AM #4
snow junky's Avatar
snow junky snow junky is offline
snow junky is on a distinguished road
snow junky's Avatar
I have 260k mi on my 3rz and just replaced oil filter housing gaskets due to a leak. No other leaks
97 4runner 3rzfe 5speed
D44 sky mfg sas
Dual transfer cases
toyo 37s 5.29 locked F&R
York OBA compressor
snow junky is offline   Reply With QuoteReply With Quote
Old 08-17-2021, 04:02 AM #5
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
How difficult was it to replace
Old 08-17-2021, 08:55 AM #6
cleanrunner's Avatar
cleanrunner cleanrunner is offline
cleanrunner is on a distinguished road
the oil filter housing gasket/seals are quite easy and cheap to replace.
Don't Text And Drive
cleanrunner is offline   Reply With QuoteReply With Quote
Old 08-17-2021, 09:33 AM #7
JZiggy's Avatar
JZiggy's Avatar
Here's my writeup on replacing those gaskets
https://www.toyota-4runner.org/3125252-post174.html
Old 09-05-2021, 06:38 PM #8
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Found it
Finally found the oil leak. Its the oil pan gasket (which is just RTV), mine is leaking on the passenger side near the oil filter. The oil is oozing out and when I shined a black light on the seam, the thing was basically highlighted orange along the whole side (UV dye in oil).
Anyone know how many hours Toyota bills for the oil pan gasket? Doesn't seem very easy to reach.
I also believe the oil filter or its housing is leaking because there is always oil clinging to the bottom of the filter. Don't know which seal specifically is my issue, but it is likely leaking as well.
1998 4runner 2.7 manual
Old 09-07-2021, 09:50 AM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Do you have a 2wd or 4wd?
Old 09-07-2021, 06:54 PM #10
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I have 4wd
Old 09-07-2021, 07:48 PM #11
JZiggy's Avatar
JZiggy's Avatar
I have 4wd
Have to pull the front diff which is a big job but doable like everything on a 3rd gen.
Old 09-08-2021, 09:32 AM #12
Real Name: Patrick
Real Name: Patrick
I have 4wd
ProDemand (labor time guide website used by auto repair shops and extended vehicle warranty companies for labor times) only lists labor times for 2wd 4 cyl oil pan which is 3.1 hours. I would expect around 2 more hours to remove the front differential.
EDIT: Labor time for front differential housing removal is 7 hours.
Old 09-08-2021, 12:56 PM #13
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I'll just live with the leak then. I have more pressing issues.
Old 11-12-2021, 01:47 AM #14
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Reviving this old thread because I noticed during my exhaust job that the leak is getting worse. Oil seems be leaking out the back of the oil pan too, and its beading and streaming down the front of my transmission.
I might dye the transmission fluid to make sure it isn't contributing to the mess, but the sump gasket that is chunking off does seem like it could be the sole contributor.
If just removing the front diff takes 7 hours on a 4wd then the gasket replacement must be 10+ hours. If I were to pull the front diff are there any other services that should be performed while its off?
Would removing the front diff need special tools or access to a lift?
Old 11-12-2021, 08:25 AM #15
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Tim the Toolman did a video on it Front Differential Replacement - YouTube
brillo_76 is online now   Reply With QuoteReply With Quote
engine , leaks , oil , pan , sump
Common Vacuum Leaks? mjquillici Classic T4Rs 5 07-31-2021 03:42 PM
Again with the Leaks! adkinsadam1 4th Gen T4Rs 11 03-09-2014 01:15 PM
Leaks all over rbdhd 3rd gen T4Rs 7 04-02-2012 10:14 PM
93 leaks kroo88 Classic T4Rs 4 04-21-2011 11:58 AM
Common oil leaks on front of motor? Daveed Classic T4Rs 7 01-29-2007 11:23 PM
