11-20-2023, 09:49 AM
Can our reflector housings handle 100 watts?
I found out that Koito (Japanese bulb maker) makes some H4 bulbs that are 100/90 watt and I wanted to look into making the switch for some better OEM housing light. (Just not a fan of projectors and all that fancy stuff)
Now, I did read that the stock wiring harness isn't going to handle that power, so I was going to order one of those plug-n-play harnesses that uses the OEM one as the relay trigger. However, I cannot find anything about whether or not the actual reflector and housing can handle 100 watts. Do we have any information on that? Id rather not melt the reflector... Haha
11-20-2023, 11:07 AM
This was recommended in a thread:
Amazon.com
Amazon.com
I put these items on a wishlist. I can't remember what thread it was... I'll take a look at my Likes and see if I can find the post/thread.
EDIT: The Likes only go back a month or so. I guess the forum doesn't store that stuff like they do the Quotes.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
11-20-2023, 11:18 AM
I recommend you have a look at VLEDS led H4 bulbs. Super high quality, significant improvement in lighting, and no worries about wiring or melting anything. They started a 30% off sale today too.
11-20-2023, 11:21 AM
Thats what I did, note my review and others though as the harness needed to be rebuilt. I was also concerned about the heat, they do get very hot, no problems yet, but i rarely drive at night, do not have DRL's, I used 100/80Hellas, and cooler climate. I also have fogs anytime and with high beam mod which is nice.
11-20-2023, 11:33 AM
Real Name: Patrick
Real Name: Patrick
I couldn't find your review on Amazon. What did you have to rebuild on them?
11-20-2023, 11:48 AM
I'm not a fan of LED's at all; especially for an older rig. Plus, unless those are special or something...putting an LED bulb in a reflector housing will blind everyone.
I saw some folks saying the temperature increase was about 20-30 degrees F, but I've no idea if that is a lot or not and that was on a 2nd gen taco.
So, did you burn out the stock wiring? Or did you use a harness and your stock wiring still messed up? Sorry I just don't follow.
11-20-2023, 12:19 PM
So will putting 100/80 or 100/90 bulbs……
11-20-2023, 01:33 PM
Why so? I've never heard of halogens causing glare in reflector housings if they are aimed properly. I mean I guess if you did 500 watts maybe it would.
11-20-2023, 02:18 PM
I've been running the Hella H4 80/100W bulbs (with harness) for about 6 months and my housings are fine. No noticeable wear, no melting or tarnishing of the reflector. I think you should be good to make the upgrade.
'99 Limited, 260k
11-20-2023, 11:20 PM
That's good to know. How is the output?
11-21-2023, 12:03 AM
Actually not true, provided it’s a well designed LED and the headlamp is properly aimed. One of the reasons I use VLED’s is because they design them to have the led chips firing at the correct place on the bulb, the same place even with where the filament would be on a halogen bulb. This ensures the light distribution into the reflector is optimized. I can’t speak to the cheap stuff.
That said, I’m sure you’ll find a good halogen solution.
11-21-2023, 09:07 AM
Real Name: Patrick
Real Name: Patrick
I have yet to come across another vehicle with led bulbs in a halogen housing that had a good pattern/cutoff and didn't blind everyone on the road. There's a reason auto manufacturers aren't putting led bulbs in halogen housings. Halogen housings are for halogen bulbs. Projector housings can be used with any bulb type provided they were designed for the heat output of the bulb.
11-21-2023, 12:16 PM
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by Ed_C
thanks for those links...... very informative
11-21-2023, 12:47 PM
It's so much better than stock. It used to be sketchy driving down dark roads at night, but now I can see everything. Highbeams are super bright too. Beam pattern should be about the same too, which you don't get with LED's. I've recommended this upgrade to just about everyone I know.
One thing though - if you turn off your truck and leave the lights on, it drains the battery pretty quick due to the increased wattage.
Overall, the best headlight upgrade for the money IMO.
'99 Limited, 260k
