10-27-2013, 05:55 PM
Replacing power adapter /cig lighter port on a '98?
Apparently, there is some kind of fuse-like thing built into the cig lighter than can blow under load. I was airing up my tires and my air compressor quit, because the front cig lighter went dead. My rear cig lighter also used to work, but that died a while back as well.
I did check the wiring behind the front one, and
@ Snowy21
checked my fuses. All seems to look good...
What should I do? Is there an easy way to fix this or just replace the entire assembly?
Thanks!
1998 T4R SR5 Natural White 4WD 5VZ-FE-V6-3.4L / ARB / Subaru-Hilux Gauge Pack / 199mm TBU / BFG All-Terrain KO2 265/70/R16
Build Thread. T4R & adventure photolog.
10-27-2013, 06:20 PM
Hi Farmerjon,
There is a fusible link at the back of the cig. lighter holder. It blows when a heavy load is been drawn.
You can remove the 8 mm nut at the back of the cig. lighter holder. Keep a track of the series of items placed in the bolt. If you want, I can get two fusible links shipped out to you.
PM me your address (sorry, I missplaced your address!)
Let me know.
nissanh
03-25-2019, 10:12 PM
Hello, This just happened to my 98 as well, compressor blew the outlet. I checked all the fuses, which look good, yet still not working. What was the solution? Did you replace the entire outlet? Thanks!
98 ltd, 199k
03-26-2019, 08:52 AM
Hello Ghill - if you look back at my first picture, at the "brass" metal between the black plastic and the whitish/yellowish plastic, there is a fuse in there (not a standard fuse).
@ nissanh
was extremely kind and found me some - called "fusible links" according to his post. Easy enough to replace, just need one of these:
Most partouts might have one, if you tell the seller where to look and how to take it apart (see nissanh's instructions above), but may have to find a way to have them bench test it. Or see eBay. I'd advise getting several while you're at it, as the back port can have this issue and it's great to carry a spare onboard for when you're airing up and things blow.
eBay link: 12V Cigarette Lighter Power Socket Fusible Link/Thermal Fuse Toyota Subaru Honda 822422725169 | eBay
Good luck!
03-26-2019, 11:41 PM
Real Name: Vince
Real Name: Vince
If you want to replace them with OE, the part number is 85530-06010. They typically run anywhere from $15 to $20 each.
If I had to replace mine again, I'd go with the ones that
@ norcalassassin
linked to. Hard to beat $8 each.
'99 Millenium Silver SR5. Auto, Shrockworks front bumper, Engo winch, Tundra 231mm, Toytec Ultimate lift, Light Racing UCAs, Tundra wheels, 285/70/17" Duratracs, B&M trans cooler, Whitson Metalworks short roof rack.
02-27-2021, 02:23 PM
Real Name: Garrett
Real Name: Garrett
Originally Posted by norcalassassin
Would it be unsafe replacing the stock socket with a fusible link, with an aftermarket one that doesn't have a fusible link?
02-27-2021, 02:46 PM
The fuse is there to prevent frying the wire further up the wiring harness which could get expensive.
You might want to consider using one of these if you must plug in high amp tools or the like into a cigarette lighter. It clamps on directly to the battery posts.
02-27-2021, 06:45 PM
Real Name: Jerod
Real Name: Jerod
I was just going to suggest the same thing. The cig lighter isn't mean to carry a heavy load, it's more for small electronics. An air compressor should be run off the battery itself.
02-27-2021, 06:48 PM
Real Name: 3 Bears
Real Name: 3 Bears
thats what I got too. just go direct to battery with its own fuse, then you wont overload your ports/lighter . mine packs small enought to fit in the same bag as compressor.
02-27-2021, 10:42 PM
Real Name: Garrett
Real Name: Garrett
Yea I was only asking whether it was safe to replace stock 12v that has a fusible link, with an aftermarket one that doesn't because i replaced my stock one with a voltage meter that has 2 usb plugs for my phone. Want to make sure I'm safe not having that fusible link anymore
02-28-2021, 01:23 AM
If you have just the 2 USBs and the voltmeter then I wouldn't worry about it. USBs should never pull enough current to damage any wiring.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
08-21-2021, 10:30 PM
Since I don't plan on running anything with high amps I just took the assembly apart bypassing the cigarette lighter fuse.
To do this start by disconnecting the quick connect then simply pry up on the top assembly after taking the 7mm nut off. Remove the plastic washer between the two pieces and reassemble. This bypasses the fuse and works great if you need an instant fix.
Hope this helps someone out
