Old 08-21-2021, 01:14 PM #1
NJ-4Runner NJ-4Runner is offline
NJ-4Runner will become famous soon enough
Rear axle options for 2001 limited with ABS
A good friend of mine has to get a new rear axle for his 2001 limited with ABS. We have verified the ratio as 4.10 with the spin test, this matches the axle code on the door jamb. It does not have an E-locker.
Will any 4.10 axle with ABS from a third gen work as a replacement? Is a Tacoma axle an option?
He picked one up from a yard last night, guy at the junkyard said it was an ABS axle with 4.10s, it ended up being a non-ABS with 3.90s....awesome.
NJ-4Runner is offline   Reply With QuoteReply With Quote
Old 08-21-2021, 07:24 PM #2
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
Yes all year rear axles will fit, but the brakes for the 2001-2002 are different. If you throw a complete axle in there it will work (I have done it on my 2001) but there are some unknowns as in does the abs system mesh properly. A tacoma axle is only the same on the e-locked rear axles, but you have to remove the mount for the leaf spring and weld on a mount for the coils. Not worth it unless you are desperate and good with a welder
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 09:46 AM #3
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Is the housing on his '01 shot or is it another issue? If it's just the housing is rusted through, you can swap all the stuff from the '01 axle onto the other one, diff included, assuming neither is an elocker axle.
ETA - this assumes a non-ABS axle has the fittings for ABS sensors and they're just blocked off. I don't know if that's the case.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 08-23-2021, 01:20 PM #4
Thanks. I forgot the Tacoma axles had leafs. Also good to know about the brakes being not identical. It appears that the easiest way to go is to find a 2001-2002.
The housing itself is shot....rusted through at the center. Also the one axle seal is wasted. He was looking to kill 2 birds with one stone. The non-ABS axle he got did not have the provisions for the ABS sensors. The bosses for the sensors are integrated into the end of the axle tube, they are part of the tube. The axle he got from the junkyard just didn't have the provisions for ABS, nothing was blocked off per say.
Old 08-23-2021, 03:40 PM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You will need an axle from a 96-02 with abs. 01-02 would be a direct swap. All other years will require transferring the brake line components over. Tacoma axles are missing all the suspension mounts needed for a 4Runner.
abs , axle , limited , rear , work
2001 rear axle housing w650gb500 For Sale: T4R Items 2 10-08-2016 09:58 PM
Rear Springs for 2001 Limited 4x4 welfels For Sale: Suspension/Wheels/Tires 3 01-06-2016 11:05 PM
Rear axle options? Chill will 3rd gen T4Rs 21 10-16-2015 08:29 AM
WTB: Rear axle for '99 Limited Nates_NW4Runner Want to Buy/Trade 0 11-04-2011 05:52 PM
rear axle options? timatraw 3rd gen T4Rs 5 11-02-2010 10:26 PM
