Old 08-24-2021, 12:06 AM #16
HiLife HiLife is offline
Do you have abs? Could be a huge air bubble made it to the unit too.
You may have to cycle the pump, bleed, cycle, bleed, a couple of times to get all the air out of it.
Braking on a slick road will cycle the pump. Ex: dirt road, water soaked road.
Old 08-24-2021, 11:31 AM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Why not use one of those that have a hand pump vacuum on them from the bleeders? That way you can pull a vacuum on each of the bleeders and basically suck the air out of your brake system.
Might even be able to borrow on of those from the auto parts store.
I did this on a 1998 which I believe has the same master cylinder as the 1999
and i bleed with the engine running so everything had power. Granted I didn't let the system loose its fluid prime but I figured the abs and vacuum assist from the master cylinder would be good start.. :-)
Old 08-24-2021, 01:17 PM #18
Originally Posted by Chris_Overland View Post
I did not have the engine running. I have a 1999 so as far as I'm aware the engine does not need to be running. The key was on though. For sure seems like I have lots of air in the lines, I did not cap off the lines and it sat overnight, but the reservoir was never empty.
Half your reservoir got empty, and you likely pushed some air into the ABS actuator. Lesson learned about always capping the lines, eh?
Even in the earlier 4Runners, it sometimes helps having the engine on to help the bleed process, though that isn't guaranteed to help and shouldn't be required.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-24-2021, 02:37 PM #19
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
you beat me to it.....my last tbu that is what i had to do. but you dont have to be going fast....just stomp on the brakes a few times so they lock up like said above...on a gravel or wet road...then bleed again.
then of course adjust back brakes....if cams or cable not frozen it might take a lot of pulls on the ebrake to get it to the recomended 7 or so clicks.
if the cams are frozen....you can go through the reqr brake drum with a screwdriver. ive been lucky and no frozen/rusted cams.
unfurtunatey for me...i will be doing this all soon....as I have a bad rear wheel cylinder....so replacing both and the shoes. and while at it im replaceing all hoses with ss lines....hey they are 20+ years old...they do go bad and can look perfect from outside....but I had one car where the line was bad,,,,swelled to the inside,,,so you could not see it, just could not figurre out why that caliper was so hard to bleed....pulled the line at the caliper...pushed the pedal...was like a blocked artery.....not much flow.
for me....anyone doing a tbu with these old rigs should at least replace the front lines if not all. new lines,,,does not have to be the ss braided....but with the money your already blowing on a tbu...why not do the best lines.
Old 08-31-2021, 09:32 AM #20
Chris_Overland's Avatar
Chris_Overland Chris_Overland is offline
Chris_Overland will become famous soon enough
Yeah, I had major air in the lines, had to take it to the shop for them to bleed the master cyl as well. Brakes still felt spongy so I cycled the abs a bunch on a gravel road and bleed them myself again at home. WAY better now!
1999 Imperial Jade Mica Limited
Bilstein 5100 & OME 881/891
SpyderTrax 1.5 spacers
Tundra brake upgrade
238,000 and still kickin
Chris_Overland is offline   Reply With QuoteReply With Quote
Old 09-01-2021, 05:12 PM #21
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
That's a really great idea. I wonder if that's why so many people complain of a mushy pedal after doing the TBU. I was super careful and only a few drops ever came out of the lines when I was doing mine and never had an issue. Didn't think about the air being stuck in the ABS pump for others an how hard it would be to get it out.
326WHP 347TQ
Old 09-01-2021, 05:33 PM #22
Each member work on their differently. And the newer ones new to wrenching, are just starting out. I applaud them on learning how to wrench on their rigs.
Some find no issue is letting the whole brake circuit bleed out thinking "I'll just bleed it and it will be good". And that's fine if you know how to untrap the air out of the circuit. The newer wrenchers may not know how as they are just starting out.
The correct way is to trigger the abs motor via computer while bleeding. Not many has that kind of tool. Almost everyone knows of a dirt road near by.
brake , front , pistons , tundra , upgrade
Spongy/Long travel Brake Pedal w/ Tundra brake upgrade 2002_thundercloud 3rd gen T4Rs 9 07-23-2023 10:07 PM
Tundra Brake Upgrade: Brake Pads Side Specific? trevo_man 3rd gen T4Rs 3 10-05-2016 11:45 PM
Did tundra brake upgrade and brake pedal mushy. 3rdgenfan 3rd gen T4Rs 5 10-25-2015 08:51 PM
is Tundra brake Upgrade = Sequoia brake Upgrade??? infamousRNR 3rd gen T4Rs 11 02-20-2014 05:22 AM
