Old 08-21-2021, 11:36 PM #1
biglar biglar is offline
biglar is on a distinguished road
Brake Lights Don't Work
I had 3 people stop me the other day to tell me I had no brake lights on my 2002 T4R 3.4 auto 4WD SR5. When I got home, I did the basics - checked fuses under hood and in panel on left corner of dash. Pulled the tail lights and checked the bulbs. No joy. Do the brake lights have a separate relay in the under-hood fuse box ??
Yesterday, I got under dash and pulled the plastic panel under steering column and went after wiring and brake light switch. Awful job - there's no room to work, but did get the brake light switch out and tested it carefully with an ohm meter. It works fine.
There's an aftermarket alarm system wired into that area which makes it much more awkward but seems like all connections are good.
Now I'm kind of at a loss. Don't know what or where else to check. Any thoughts out there ??
Quite a while back I commented that my 3 yellow dash warning lights for ABS, VSC, etc. were stuck on, tho' everything seems to function OK. No codes showing on the OBD. Once in a while they'll go out for a day or 2, then come right back on.
When it did that before, it was "both" O2 sensors and when I replaced them the gas mileage took a great jump up. I'm afraid the mileage is hurting now, too, tho' I haven't taken time to check it.
I'm planning a 4,000 mile trip next month and would really like to get all systems sorted and working properly. Thanks.
biglar is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 07:10 AM #2
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Are all of your brake lights (both tail lights plus your CHMSL) out or just the tail lights. If all of them are out, check the switch on the brake pedal for failure.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 10:22 AM #3
Yah, as I said above, I checked the bulbs and all are good. The tail lights and turn signals work fine. Only the brake lights out. Again, I pulled the brake light switch on the pedal and it checks out fine on the ohm meter.
Old 08-22-2021, 10:51 AM #4
Do you have power at any of the sockets when you depress the brake pedal? Do you have switched power coming out of the switch?
Old 08-22-2021, 11:22 AM #5
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
This! Ohm sockets themself with someone depressing the brake pedal. If good (which I suspect they would be ) then pull the pedal switch and ohm test when it should have switched power ( i.e pressed brake pedal).
I suspect the pedal switch to be the culprit as it would be an odd coincidence to have all three sockets fail simultaneously.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 08-30-2021, 08:31 AM #6
It must've been a dirty connection at brake light switch. I tore into it again and all was the same as before. Connected it all back up and the brake lights work now. Didn't repair anything, didn't change anything. Phew.
Thanks for all the replies and thoughts, tho' I do think some of you need to read more carefully before jumping in.
I still have the VSC and ABS lights on all the time, tho' I've tested the 4WD repeatedly and it does go in and out of lock and the 4WD does work properly.
The 4 little lights on the instrument panel function normally as does the blinking yellow one.
No codes are showing on the OBD readout.
I put it up on blocks and crawled under there and it's very awkward reaching the connectors, but I did get them loose and re-plugged them on. Didn't make any difference.
My big concern is the trip coming up soon - I'd much rather get 22 mpg than 16 mpg
Old 08-30-2021, 10:17 AM #7
spartacus's Avatar
spartacus's Avatar
Check the Brake fluid fill up to the correct level.
Take out Tha abs sensors and clean them check the wiring for cracks etc.
Old 08-30-2021, 10:25 AM #8
Brake fluid is easy.....where are the ABS sensors ?? Thanks for the reply.
Old 08-30-2021, 11:13 AM #9
spartacus's Avatar
spartacus's Avatar
They are on the axles close to wheels held on by 10mm bolts.
Good pics of lines and sensors in the following thread.
3rd Gen ABS Front Wheel Speed Sensor Test and Replacment
Old 08-30-2021, 12:18 PM #10
Thanks again. I'll check it all out and let you know.
Old 08-30-2021, 12:50 PM #11
Just be careful pulling the ABS sensors out. If you live in the rust belt, they can be corroded in there pretty good and attempting to pull them out can turn one into a paper weight. Besides, they have nothing to do with your brake lights being out.
Old 08-30-2021, 01:04 PM #12
spartacus's Avatar
spartacus's Avatar
His brake lights are working (post # 6) his abs dash light is on.
Old 08-30-2021, 03:59 PM #13
Darndest thing - the "wouldn't ya know it," dept.
I checked the master cylinder reservoir and the level of fluid Is down - almost to the seam around the tank. OK, didn't touch it, closed the hood and went into town for errands - including to buy some fluid. The lights were out....and they stayed out, thru several stops and engine stops.
I did buy a can of fluid and I will put it in in a bit, but this is very likely the problem. Thank you.
Old 08-30-2021, 05:37 PM #14
Great! Now you have to ask the next question: Why did the fluid level in the master cylinder get so low? It may be that your brakes are worn down significantly and all of the fluid is downstream in the system. Then again, you could have a leak somewhere. Time to do some more detective work.
Old 08-30-2021, 08:35 PM #15
It's deceptive. Looked like the fluid was way down, but when I went to add more I saw that the filler extends down into the tank. It only took a few ounces and it's been about a year since I added any. In the morning I'll look underneath to be sure, but I think I'm good. Many thanks.
back , brake , dash , lights , pulled
Brake lights wont work please help. T4Trail 5th gen T4Rs 8 01-23-2017 05:20 PM
Help: 2002 brake lights dont work bigtimeweb 3rd gen T4Rs 2 11-22-2015 07:07 PM
2007 4runner lights, horn and blinkers work, but hazard will not work rki1966 4th Gen T4Rs 1 09-21-2014 02:08 PM
Plugged my new trailer into 4R and brake lights/turn signals don't work mac0822 4th Gen T4Rs 3 05-23-2011 12:50 PM
94 4 runner won't shift out of park, and brake lights dont work ezekel Classic T4Rs 4 05-24-2006 08:54 PM
