Old 08-22-2021, 03:18 PM #1
Levitan Levitan is offline
Levitan is on a distinguished road
No Battery Light with Key on.
1999 Toyota 4runner Limited, 4x4, 3400, auto, 150k
For starts, I'm the kind of guy that tries to research and fix things on my own, usually not asking questions. This time, I'm lost and hope somebody can give me a path to follow.
Typical situation, driving at night, check engine light comes on, headlights dim, I figure it's the alternator. Go to Advance Auto, get replacement. Install. Start my ride, zero charge. Do the Google machine deep dive and discover that if the "battery light" in the cluster doesn't turn on with the key in the "on" position, it won't allow an "ignitor", I believe, to tell the alternator to charge. So, turn key on, no battery indicator light. Must be blown bulb. Pull the cluster, swap the "battery bulb" with the "seatbelt bulb", seatbelt light comes on, still no "battery light". So, bulbs are good. I checked the fuse in the dash and it is good.
I am absolutely lost with the next steps to take. I'm relatively mechanically inclined. I have plenty of tools, voltmeter, Haynes manual, etc. I just need help from somebody who is fluent in 4runner electrical and is a good teacher. Any help or directions would be much appreciated.
Levitan is offline   Reply With QuoteReply With Quote
Old 08-22-2021, 04:01 PM #2
Skulking Skulking is online now
Skulking has a spectacular aura about Skulking has a spectacular aura about Skulking has a spectacular aura about
What code was the CEL for?
To confirm what you have done, you noticed your lights dim and threw a CEL. You assumed it was the alternator so you replaced it. After you replaced the alternator, "Zero charge". Does that mean the new alternator isn't charging? How did you confirm that? Do you mean your car won't start because the battery has no charge?
Skulking is online now   Reply With QuoteReply With Quote
Old 08-22-2021, 04:27 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
Check your battery voltage with a volt meter 12 volts is low and fully charged colser to 13volts.
5 3rd gens listed in the build thread
Old 08-22-2021, 05:12 PM #4
spartacus's Avatar
spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold
spartacus's Avatar
Test the 3 pin connector for continuity on the alternator one of those wires goes to the battery light. The other is ign wire from the fuse box to the alternator. If the wires are cut or loose. The battery wouldn't charge.
auto , battery , bulb , key , light
4th Gen No Codes No Start & Battery Light On, It's not the battery! V8Man 4th Gen T4Rs 18 10-05-2019 10:35 PM
Please help - Engine shut off + Battery light, A/T Fluid light and OIL light Lamer 3rd gen T4Rs 11 09-03-2018 06:04 PM
Battery Light + Whine + Low Idle + New Battery TT4RLtdV8 4th Gen T4Rs 21 01-12-2018 10:43 AM
Battery light flashing and abs light rooney2422 3rd gen T4Rs 0 10-15-2014 06:54 AM
A/T Oil Temp Light accompanied by Battery light YotaDriver19 Classic T4Rs 5 09-28-2011 10:44 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
