Old 08-23-2021, 06:14 PM #1
Deej101 Deej101 is offline
Deej101 is on a distinguished road
2001 SR5 Fuse box doesn't match diagram?
The inside driver kick panel fuse box layout is different from the diagram inside the cover.
Mismatch? Anyone have the correct diagram?
For that matter, does anyone have the FSM Electrical Supplement for the 2001? I have the 2000 and 2002 ones, so worst case can do subtractive deduction, but if a 2001 is a available, would like to take a look.
Thanks!
2001 SR5 Fuse box doesn't match diagram?-fusebox-jpg  2001 SR5 Fuse box doesn't match diagram?-fuseboxdiag-jpg
Deej101 is offline   Reply With QuoteReply With Quote
Old 08-23-2021, 06:55 PM #2
RTFM... see page 275:
https://www.toyota.com/t3Portal/docu...f/OM35768U.pdf
Looks like somebody has been in there and messed with your fuses. A number of those are not OEM.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-24-2021, 09:49 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It looks like they added extra fuses in the blank spots and changed a few fuses around. Have you tried removing a fuse to verify the label is correct? It wouldn't be hard to do. Just pull the "stop" fuse and check for brake lights, then pull the wiper fuse and check your wipers. If those two work it's quite likely the label is correct.
Old 08-24-2021, 01:36 PM #4
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Thanks!
I have always used 2002 as a substitute for 2001. There were very few changes as 2002 was the final year of the generation. On the other hand, there were substantial changes between 2000 and 2001.
My Backyard Frame Swap
Old 08-24-2021, 03:13 PM #5
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
read/listen to this guy, he saved my arse on a vacum issue when i was in the middle of bum frick no place in the snow many years ago when no one else had the fix,,,with a 4wd that quit working. he know these things electrical and vacum. hes da man. he will walk you to a fix...might take a few emails...but i believe he will help you do it.
btw....thanks "the Durk" again for your help years back
Old 08-26-2021, 01:36 PM #6
Boy, that's an understatement... I'm curious as hell as to what the PO(s) were thinking when they did whatever they did; still trying to decipher this mess (topic of another thread).
2001 SR5 Fuse box doesn't match diagram?-wiringmess-jpg
Old 08-26-2021, 01:38 PM #7
Good suggestion, will try that soon, thanks!
Old 08-26-2021, 01:39 PM #8
Great, that is good to know, thank you!
box , diagram , fuse , inside , worst
Ignition key doesn't match door key white_n_slow 3rd gen T4Rs 6 11-04-2013 04:54 PM
Fog Light Mod...doesn't match piccrazy30 4th Gen T4Rs 11 09-15-2013 07:44 PM
Fuse Box Diagram redpoint Classic T4Rs 1 01-09-2011 11:35 PM
Galactic Grey touch up doesn't match cyclops24 4th Gen T4Rs 11 01-24-2006 11:01 PM
1990 Fuse Box Diagram? rghrdr18 Classic T4Rs 3 11-23-2004 10:49 PM
