08-24-2021, 12:23 PM
Real Name: Matt S.
Real Name: Matt S.
Some Questions About Brake Upgrades
I am getting ready to do the tundra brake upgrade. I would like to replace my master cylinder as well. I was just on rockauto.com and noticed that they want $109 for an Advics master cylinder BMT-035 for 4runner, but only want $68 for a Landcruiser FJ80 Advics master cylinder BMT-046. I think the only difference is in the orientation of the port connections. I am also pretty sure that the Land Cruiser masters have residual valves for the rear brakes, however the notes for the 4runner master cylinder BMT-035 indicate that it is suitable for rear disc brake applications. Do you see any reason why I shouldn’t order the substantially less expensive Landcruiser part?
An additional note. I have almost everything I need to do a rear disk conversion so I probably want a master cylinder with residual valves.
1999 SR5 3.4 auto, Horizon Blue Metalic 8N1, blue cloth, steel Daytona wheels, 265/75/16 AT tires, rear heat, A/C, sunroof, electric locking rear dif.
08-24-2021, 12:39 PM
Real Name: Matt S.
Real Name: Matt S.
Some nice calipers that I found at a wrecking yard for $35 each. I see a lot of other yards asking as much as $80 for badly corroded parts.
08-24-2021, 03:26 PM
Real Name: Patrick
Real Name: Patrick
I vaguely remember something about the bolt pattern being different, but I couldn't tell you for sure.
08-24-2021, 07:08 PM
Real Name: Matt S.
Real Name: Matt S.
That would be very un-Toyota-like. Consistency is the best description of the Toyota I know.
08-24-2021, 07:18 PM
Real Name: Matt S.
Real Name: Matt S.
My 4runner is just getting ready to pass 300k miles. In addition to brake work, I am thinking of replacing other parts as a matter of preventative maintenance. The timing belt, lower ball joints, shocks, springs, spark plugs, and ignition coils are on my to do list.
08-25-2021, 09:21 AM
Real Name: Matt S.
Real Name: Matt S.
There is one other thing I’m going to need to complete this brake upgrade. Wheels! The vehicle currently has Daytona style steel wheels (16”x 8”). I had to grind a small area on the calipers to make them fit. They are definitely not going to fit once I get the Tundra calipers installed. This brake upgrade is the excuse I have been looking for to get the wheels I’ve wanted for a long time. These are 16” x 7 five spoke alloy wheels that seem to have been an option on 4runners from 1998 - 2002
08-25-2021, 12:11 PM
Real Name: Patrick
Real Name: Patrick
As far as I know, all 3rd gen 4Runner's had a 1" master cylinder bore which is the same as an FJ80. I'm pretty sure the FJ80 is a 4 bolt flange and the 4Runner one is a 2 bolt flange as well. I don't have time to read through all the threads but here's some you might look at:
TBU with a twist
Replace entire Brake system with Tundra's?
Master Cylinder upgrade options
08-25-2021, 06:06 PM
Real Name: Blair
Real Name: Blair
I might have missed it, but are you doing the 231mm brakes? I'm not clear on the caliper markings.
08-26-2021, 10:22 AM
Real Name: Patrick
Real Name: Patrick
13WL stamping is 231mm brakes
08-26-2021, 02:08 PM
Real Name: Devan
Real Name: Devan
Already went down this road, not possible I don't think. See below
08-29-2021, 10:52 PM
Real Name: Matt S.
Real Name: Matt S.
The posters who said that the Land Cruiser master cylinder has a four hole mounting pattern are right. I have mostly worked with older Toyota pickups and 4runners where the Landcruiser master cylinder is considered an upgrade for disk brake conversions. They share four hole mounting pattern as well. It seems that the third generation 4runner was the first to get the two hole. Thanks to those who gave me the correct information.
