09-30-2013, 09:47 PM
4 runner died while driving
My daughter was drive her 1996 4 runner down the road and lost all power and the 4 runner died. Now when you try to start it nothing happens at all. All accessories work, horn,radio etc.. Put load tester on battery and it checks good. Does anyone have any suggestions?
09-30-2013, 10:02 PM
Real Name: Anthony
Real Name: Anthony
Are you saying the motor doesn't turn over or the motor doesn't fire up?
09-30-2013, 10:07 PM
won't turn over
09-30-2013, 10:57 PM
Real Name: Danny
Real Name: Danny
Stater?
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
10-01-2013, 09:04 AM
That might be way it doesn't crank, but that couldn't cause it to quit running while driving down the road. I'm going to pull the started and check it out.
Thanks
10-01-2013, 09:34 AM
Real Name: Brad
Real Name: Brad
Could it possibly be the coil packs on the spark plugs? My old Honda did this and the distributor was fried. Just throwing ideas out. Good luck.
Utah Desert Runners T4R
1997 T4R Limited
2004 TRD Tacoma xtra cab---Sold
10-01-2013, 10:57 AM
We had a similar problem on the road recently. We did a lot of trouble shooting and checked the gas cap, idle air control valve, coil packs, battery and fuses.
It ended up being the mass air flow sensor. It's easy to pull and inspect. This one had a piece of fur/lint from a shop rag or something similar. Clean, reinstalled and back on the road.
10-01-2013, 11:12 AM
Real Name: Isaac
Real Name: Isaac
will it cank over, but not start, or just not crank? does it make a "click click click" sounds when trying to start?
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
10-01-2013, 12:22 PM
Timing belt snap?
1996 4Runner SR5 4x4 / 275,000 Miles / All Stock
10-01-2013, 12:33 PM
Real Name: Kevin
Real Name: Kevin
If it suddenly died on the road and won't crank at all, it isn't going to be the starter or the dist or the timing belt. I too want to know if there's a click or a whir when the key is turned, and I'd be looking to see if the motor turns over manually with a breaker bar.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
10-01-2013, 12:53 PM
Real Name: Trevor
Real Name: Trevor
Happened to my old sport trac too. Check the alternator, batt, all electrical connections. Mine just so happened to be both a bad battery and a bad alternator
98 4Runner V8 tundra swapped 'Lucky' This that and another. My build http://www.toyota-4runner.org/3rd-ge...ld-thread.html
"I say it all the time, my truck is a hybrid damnit, it goes on and off road."
10-01-2013, 01:00 PM
I had something similar happen to my previous truck (Ford). The ground on the alternator came loose. Thats what I would check.
10-01-2013, 01:26 PM
Neutral safety switch, clutch safety switch? Bad ground? Dodge Neons would do that, was bad ground.
10-01-2013, 01:27 PM
Real Name: Trevor
Real Name: Trevor
Why is it always the ford guys that turn into toyota guys? I loved my ford but ended up loving my yota more.
10-01-2013, 01:41 PM
Real Name: Adam
Real Name: Adam
Mine did this last week. I changed the brushes on my alt a few weeks ago. It had been running fine since then. Last Wednesday, I noticed the idle got low at times when I came to a stop, and the voltage dropped pretty fast. If I gave a little gas, it went back up.
I was on the interstate coming home Friday and traffic built up, so I had to stop rather quickly...damn thing died on me! I put it in park, and it started right up. Its not my alternator, as it continues to charge my battery...I never have a problem starting.
It hasn't died on me since, but the idle and voltage still drops on me. I'm going to check the MAF sensor when I get home tonight...hopefully that just needs cleaned.
