Old 08-26-2021, 03:32 PM #1
Dmrowe Dmrowe is offline
Dmrowe is on a distinguished road
Shift delay
Good afternoon guys and gals!
A little back story before I get into the meat and potatoes.
Iíve had my 4Runner for a few years, done a whole bunch of upgrades to it, itís been my pride and joy.
I recently purchased a pop up, and started towing with my 4Runner, everything was good, I started to worry about the transmission fluid getting too hot. When going up hills she would down shift quite frequently then up shift again. Usually between 60 and 70 mph. So I installed a trans cooler and did a fluid change.
Since then, when accelerating from a stop, the trans doesnít want to shift into first for a few seconds.
Could this be a shift solenoid problem, or a trans problem?
Any input would be greatly appreciated!
David
Dmrowe is offline   Reply With QuoteReply With Quote
Old 08-26-2021, 03:41 PM #2
Bad Luck Bad Luck is online now
Real Name: Patrick
Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold
Real Name: Patrick
What transmission fluid did you use?
Have you verified the transmission fluid level is correct when hot? Should be checked at operating temperature, engine running, and in park.
How does your new fluid smell and look?
Is it a consistent problem or intermittent?
Did you perform a transmission flush or a drain and fill?
2000 Limited V6 Auto E-Locker
Bad Luck is online now   Reply With QuoteReply With Quote
Old 08-26-2021, 04:21 PM #3
phattyduck phattyduck is online now
phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of
If the transmission unlocks the torque converter while towing (slight bump in RPM, but not up past 3k), you should disable OD ("OD Off"). That will allow the torque converter to re-lock and keep your trans temps way down.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 08-26-2021, 04:43 PM #4
19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light
Define ďWonít shift into firstĒ
Starting from a stop itís in first.
How did you change your trans fluid? Did you just pull the drain plug and do a drain and fill or did you pump the old fluid into a bucket while adding fresh fluid?
You use a DEX III?
Drain the trans pan is 4qt.
Old 08-26-2021, 10:11 PM #5
Ty for the replies, it was not fully flushed, I drained the pan, refilled it, shifted gears a few times to get the fluid circulating, drove it around a few miles to warm it up, and drained the pan again. Now today, if Iím sitting at a red light, the engine revs but wonít kick into gear for about 3 seconds or so.
I used Castrol trans max high mileage fluid
Old 08-26-2021, 10:27 PM #6
spartacus's Avatar
spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold
spartacus's Avatar
Classic sign of transmission is slipping, usually caused by burnt or old fluid. When i was researching for my flush. I'didn't think Trans max was compatible with Toyota a340f.
Old 08-27-2021, 11:08 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
I would also change that screen filter. I suspect wrong or not compatible transmission fluid as well if it is all the sudden like right after you exchange it. :-)
5 3rd gens listed in the build thread
Old 08-27-2021, 07:23 PM #8
Those symptoms to me remind me of low fluid level.
4runner , fluid , shift , started , trans
Ac delay after starting. mrmachinist 5th gen T4Rs 15 08-17-2019 08:03 PM
NEW SHIFT PATTERNS! October 2016 Ellis Precision Shift Knob Group Buy! Ellis Precision Group Buys 41 08-08-2017 10:23 AM
A/C Delay Manitou74 General Discussions 1 05-02-2015 12:02 AM
1-2 slow/sluggish Shift WOT A340E 2004 2WD V6 148K. Shift Solenoid? NCSCOTT 4th Gen T4Rs 1 04-22-2014 07:07 PM
4wd Has a 30+ Sec Delay to Engage keith&julie 4th Gen T4Rs 6 02-06-2011 12:50 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
