Old 08-27-2021, 03:16 AM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Grinding when putting into 5th gear (W59)
I am having intermittent issues with my 5th gear. The first time this occurred was 3 months ago, then it happened a few days ago, then it did it again today.
When I am shifting into 5th gear I will suddenly get a gritty and rough feeling through the shifter, sometimes this is accompanied with a grinding noise. I can get it into 5th gear still, but the sensation is concerning.
But the odd thing is that the issue will resolve itself later in the same drive, I will downshift and then go back into 5th and the issue is gone. Both times I remember this happening it occurred during the first shifts into 5th gear of that drive when everything might not be warmed up. This grinding happens with the clutch 100% in, there is no chance this is the result of me letting it out accidently (I checked).
The increasing frequency of this makes me concerned. I replaced my transmission fluid about 1000 miles ago (Redline MT90), the old fluid was very dirty looking. The clutch is likely original, I say likely because I got zero papers with my 4runner and it had 165k on the clock.
Any ideas what the issue might be?
Pyral is offline   Reply With QuoteReply With Quote
Old 08-27-2021, 08:43 AM #2
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
How're your shifter bushings?
Clutch pedal adjusted?
If you rev match does it help? If so it sounds like you just have a synchro wearing out.
JZiggy is offline   Reply With QuoteReply With Quote
Old 08-27-2021, 09:31 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I agree with Jziggy. If everything else checks out a sync is going...
Old 08-27-2021, 01:22 PM #4
If it is going out, run a quart of GM Synchromesh fluid in there with your fluid of choice to help reduce the grinding... Sometimes really 'good' fluids will cause weak synchros to grind a bit more than they did before a fluid change and the GM Synchromesh (or compatible) fluid is specifically meant to keep synchros happy.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 08-27-2021, 02:19 PM #5
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Why does it only grind sometimes and only at 5th?
Old 08-27-2021, 02:40 PM #6
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
You have synchronization rings between every gear and they wear independently of one another, but chances are in the past either you or the PO routinely abused that shift. Or it could be because those gears were used most frequently in its lifetime and it's just wore out. At 20 years old and a couple hundred thousand miles, it can be anyone's guess.
Sometimes they make noise and sometimes they don't, because sometimes they're working properly and sometimes they're struggling to keep the speeds matched. That's how a failing part behaves generally, sometimes it works fine and others it causes a problem which may seem fairly inconsistent. Chances are there's a common denominator out there but it's not readily apparent, and for all intents and purposes I'd say it's really not relevant anyways - they're not gonna magically get better if you deduce and avoid it, whatever it is
You can have synchros replaced but it's typically pretty pricey (trans has to be completely broken down) and it might benefit you to find a full on replacement from a junkayrd
Old 08-27-2021, 02:49 PM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Each gear has it's own synchronizer. I'm going to guess that when it grinds you are at a greater rpm difference between the input shaft (engine rpm) and output shaft rpm. If you rev match the grinding should be less noticeable.
Old 08-27-2021, 03:57 PM #8
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
The shifting is in general notchier when the tranny is cold. Things seem to work better when it warms up. Usually it is lower gears that we have issues with, odd that yours is 5th.
I know others swear by the redline and I am not going to argue one way or the other about that. However, I have a 4 banger like you and mine for sure prefers Amsoil. I found the redline to be OK when fresh but it soon started getting notchy.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 08-27-2021, 05:16 PM #9
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Would waiting for it to get worse before doing anything cause damage to other parts?
Would you replace the clutch and the syncros at the same time?
I assume the price to replace a syncro is in the thousands if I have someone else do it. I'll try eliminating the other possible causes because I don't want to take apart the transmission if I don't have to.
If I replace one syncro should I do them all at the same time?
Old 08-27-2021, 05:43 PM #10
Real Name: Patrick
Real Name: Patrick
To replace the synchros the transmission will need to be pressed apart so if you aren't going to replace the transmission then it should be rebuilt with all new synchros/bushings/bearings. Transmission will need to be removed so it would be a good time to examine your clutch and flywheel.
Old 08-27-2021, 07:33 PM #11
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
The tranny has to be taken down just about as far as it will go for synchros to be replaced, so it would be a little silly not to replace the clutch of all things. Really at that point you should make a list of components that possibly need addressed and heavily consider making the leap while you're at it.
And yes, ignoring your synchros can cause you to damage your gears if you're not paying much attention. Without them you'll find you'll have a TINY window to shift and will likely be grinding gears together until they're forced into place. Not to mention it sounds embarrassing, generally a 2/10 experience. There's a reason they've been common place for 60-70 years, and existed for a few decades before their acceptance; driving without them is pretty shitty
Edit: If our suspicions are correct and you don't want to replace it I'd recommend taking it to a highly rated transmission service shop near you for the work and not DIY in your garage. It'll be spendy (probably around $2k if I had to guess) but the headache it'll save alone makes it money well spent.
Old 08-27-2021, 08:13 PM #12
JZiggy's Avatar
JZiggy's Avatar
I think you’re in for a trans rebuild and clutch job.
I’m actually about to do that too. My trans and clutch are getting chattery. I’d rather freshen up the bearings and synchros before anything actually goes wrong to set me up for another 250k+ miles of success
Old 08-31-2021, 02:15 PM #13
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Today the transmission did the grinding thing again. It was under the usual circumstances:
- Transmission wasn't fully warmed up
- Only the shift into 5th gear made grinding
- Grinding into 5th ceased once the temperature got up to operating
This time I tried experimenting with double clutching and that got it to not grind when it would of. So I think that is a pretty good sign that my synchro on 5th is going out. Time for a rebuild...
Old 09-07-2021, 06:44 PM #14
Eh, just double-clutch the 5th shift when cold. Doesn't seem like much of a hassle compared to the cost of a rebuild. If it gets really bad or starts popping out of 5th while driving or something - then rebuild.
Old 09-07-2021, 08:22 PM #15
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
To build on this, if anything take advantage of this time during the remainder of it's life and start saving up for a replacement or rebuild. The bill hurts a lot less when you're prepared for it, and judging by your other threads it looks like you got a handful of lots of little things that need attention. Replacing a trans is a big repair and there's no reason to treat it like it was unexpected if your car is giving you a heads up
5th , ago , gear , grinding , issue
Grinding 2nd gear jmitchell79 Classic T4Rs 4 01-19-2014 01:14 AM
Grinding Gear 2007toyota4runners 4th Gen T4Rs 4 02-09-2012 09:56 PM
Putting in Gear Immediately After Starup 4Rida 4th Gen T4Rs 10 01-23-2012 12:14 PM
Surging when putting in gear JFDATLAW 5th gen T4Rs 11 08-03-2010 09:07 PM
95' T4R SR5 5th gear grinding sound? Red Classic T4Rs 0 02-13-2008 02:23 PM
