As the title says, i'm going to be replacing my steering rack bushings soon as my steering is all over the road and I have read old posts and i'm not getting a consistent answer whether I should lift the truck on jacks or not.
The reason I ask this is because my jack stands are only rated for 2 Tons which I mainy use for my light Honda which works perfectly fine but for the 4Runner I feel like it's too heavy for them. Would it be best to disconnect both Tie Rod Ends and change the bushings on the ground? I was able to replace the sway bar bushings on the ground and had no problem doing it
This is my first ever steering rack bushing replacement.
Any answer and advice would be appreciated. Thanks.
