Old 09-11-2021, 12:50 PM #1
ryandc ryandc is offline
ryandc is on a distinguished road
Troubleshooting manual-trans 4WD, 1999
The rig: 1999 SR5. 3.4L engine, 5-speed transmission, J-style transfer case. No e-locker, no transmission mods.
The issue: When shifting into 4HI on the J-stick, nothing happens. The 4WD light on the dash does not illuminate. Car does not exhibit issues binding on tight turns that would typically occur when front wheels are locked.
Troubleshooting: Shifting into neutral (on the J-stick) functions properly. Shifting into 4LO illuminates the dashboard 4WD light, properly downshifts the car, and properly locks the front wheels.
Some googling has yielded an acronym soup (VSV, AAD, a few others). Not gonna lie, I can wrench on engines all day and do okay (my rig has 290,000ish miles and never goes into the shop), but transmission and suspension is a bit out of my wheelhouse.
What are the possible points of failure here?
ryandc is offline   Reply With QuoteReply With Quote
Old 09-11-2021, 01:34 PM #2
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Can you turn the front drive shaft by hand in 4 LO and 4 Hi?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 09-11-2021, 10:22 PM #3
nissanh nissanh is offline
Above^^. Those manual shift levers never fail.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 09-15-2021, 10:05 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Check to see if the front driveshaft turns by hand with the transfer case in 4hi and 4lo. If the front driveshaft does not spin freely, then remove the switches on the transfer case and check for continuity. When you shift into 4hi the shift lever activates a switch which in turn sends a signal to activate the front add system.
Old 09-15-2021, 01:48 PM #5
This is the answer right here. Likely a dirty/non-working switch on the transfer case to engage the front ADD.
Basically, the transfer case is correctly in 4WD, but the front doesn't get signaled to lock in for 4WD operation.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-15-2021, 02:59 PM #6
NegroTundra NegroTundra is offline
NegroTundra is on a distinguished road
Yep, what the two guys above said. Remove plastic bezel/leather around shift knobs. Look down on the right side and you will find a switch that the 4wd stick depresses when engaged (its a tight fit so be prepared to feel your way around). Remove that switch. I just had to bench clean mine with some parts cleaner and it worked again. Or replace it since your approaching 300k.
00 T4R 3.4L Sc'd Locked 4x4 (140k)
98 T4R 3.4L 5-Speed Locked 4x4 (280k)
16 Dodge Ram 2500 6.7L Cummins fully deleted
NegroTundra is offline   Reply With QuoteReply With Quote
4wd , properly , shifting , transmission , wheels
WTB 1999-2000 4Runner ECU 5VZ 4x4 Manual Trans Aelfwine Want to Buy/Trade 1 06-28-2020 06:39 PM
3rd Gen, 1999 4Runner, Manual Trans, $5000, Phila Suburbs (Chester County) nayrbs For Sale: Vehicles 1 06-12-2018 11:51 PM
1999 Manual Trans pops out of 1rst Gear William Pyle 3rd gen T4Rs 6 06-23-2017 11:21 PM
Iso 4runner frame - 1999 sr5 manual trans - please!!! Tibbs82 3rd gen T4Rs 2 03-05-2015 04:21 PM
Auto trans shifting troubleshooting southbay Classic T4Rs 4 05-25-2013 12:55 AM
