Old 08-29-2021, 12:13 PM #1
hawkcharmer's Avatar
hawkcharmer hawkcharmer is offline
hawkcharmer is on a distinguished road
What is the green/yellow wire on oem trailer hitch convertor box?
Hello,
I'm trying to figure out where the green wire with yellow line in it plugs into? Its coming out from the toyota factory trailer hitch black convertor box. I pulled it and the hitch from a scrap yard years ago and plugged it in, but not sure where the green/yellow wire goes.
Im getting ready to finally use the hitch and want to make sure that everything is working properly.
Any feedback is greatly appreciated!
99 4runner
What is the green/yellow wire on oem trailer hitch convertor box?-screen-shot-2021-08-29-11-12-32-am-jpg
1999 4Runner SR5, 3.4L 5VZ-FE V6 | Tundra/890 coils | 5100 Bilsteins all around l 199mm Tundra brake upgrade | 265/75/16 Falken Wildpeak AT3 tires | ARB Bull Bar
hawkcharmer is offline   Reply With QuoteReply With Quote
Old 08-29-2021, 01:53 PM #2
spartacus's Avatar
spartacus's Avatar
Originally Posted by hawkcharmer View Post
Hello,
99 4runner
According to the pdf it's right tail light.
see attached.
What is the green/yellow wire on oem trailer hitch convertor box?-screenshot_2021-08-27-06-41-37-1-png
Old 08-30-2021, 12:23 AM #3
Those converter boxes like to go bad at this age, so check it really well... Or just get any number of aftermarket plug-n-play options if the OEM fails. I soldered on the Toyota end at the hitch so it would still bolt on to the OEM hitch.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 09-15-2021, 10:17 AM #4
see attached.
Thanks for this information. but how does one connect the green wire? Do I splice it in to a existing wire on the right side, use t-tap, butt connector? Not sure how this is done.
Any feedback its greatly appreciated. Thank you
Old 09-15-2021, 01:45 PM #5
In OEM form, it connects into the harness using an in-line connector.
I'll suggest it again - get a new aftermarket converter. The OEM ones at this age aren't reliable (I went through two before going aftermarket). It'll be plug-n-play just like the OEM one.
Old 09-15-2021, 02:37 PM #6
spartacus's Avatar
spartacus's Avatar
Put a volt meter on it and make sure it's the correct wire, then splice it in to the existing wire coming from the front IE1 conector. I prefer soldering but you can use what ever you prefer. Make sure the ground is hooked up before you test it.
Edit: I'll second what @Patty duck said.
Old 09-15-2021, 02:48 PM #7
Thanks to you both! Much appreciated
box , convertor , hitch , trailer , wire
Illumination lighting out, green wire is now grounded? visualfxengineer 5th gen T4Rs 12 04-09-2023 03:23 PM
Traffic (green, yellow, red) no longer showing up? arehman11 5th gen T4Rs 12 08-10-2019 03:04 PM
Toyota TRD Tundra Bilstein Shocks Yellow/Yellow Yellow/Blue Springs Troybylt For Sale: T4R Items 2 10-20-2016 10:56 PM
Did factory trailer hitch include an "extension" wire Ghostrider 3rd gen T4Rs 2 11-18-2014 07:35 PM
Green Wire hydraspo 3rd gen T4Rs 4 05-17-2010 10:42 PM
