08-30-2021, 11:10 AM
Roof Rails replacement
All,
As the Title says... I need to replace my Roof Rails. These are the Rails that run from the front to the rear of the Vehicle. Does anyone know of any aftermarket Rails that i might use?
I had my Thule gear on the roof when i hit a low hanging limb. The thin lips of the rails ripped up. Good thing they were empty.
I can always just RE mount the Thule racks to a non damaged area, but the Manufacturer recommends specific distance apart to maintain structure integrity.
Thanks.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
08-30-2021, 11:18 AM
Originally Posted by giguchan
All,
Thanks.
Rhino-rack makes rtc style roof tracks channel mount in different lengths.
08-30-2021, 12:16 PM
Thank you
I'll have a look see and see what they have that might suit me..
Currently 194K
Cheers
08-31-2021, 09:43 PM
You could use unistrut and build your own. It's like 25 dollars for a 10 foot long piece.
I just built a roof rack using it, and I really like it alot. I'm about 100 dollars total into my build and it's coming together very well.
It's low profile, heavy duty, versatile, and basically an erector set for adults when it comes to putting it together.
2016 TE (WIFES)>Stock with KO2's, SW sliders
2001 Sport (MINE)>FJC front coils/C59-137 rear 5100's, 265/75r16 g003
2013 Mazdaspeed3 (MINE)> bolt ons and tune
08-31-2021, 10:50 PM
Thanks for the reply!
I'd love to see what it looks like when your project is completed.
I'm going to look into that.
Currently 194K
Cheers
08-31-2021, 11:26 PM
I'll post photos when it's complete.
I threw it together one night before a river trip, just so I'd have a way of attaching a much needed awning in this TX heat.
It comes galvanized, which is cool for corrosion resistance, but sucks if you want to paint it. They make all types of fittings for them, but I also like that you can bolt anything you want to them, by virtue of the predrilled holes they have.
When the weather cools down I'm going to take it off and paint it properly.
I made 4 more cross rails that are prepped and primed, ready to paint. Waiting on the humidity to lower before painting those. There will be a total of 6 cross rails, spaced about 12 inches from each other.
The first two that are currently on there stick out 6 inches from the main rails/tracks on both sides to allow the awning to protrude out where I wanted it.
As for the other 4 cross rails that aren't installed yet.
I used 30% vinegar to clean them, then scuffed them. Then I sprayed them with a solvent based paint prep aerosol. Then primed them with acid etching primer. Took about an hour. The primer appears to have adhered pretty well.
Anyway, all in all I think I'll end up spending $150-200 total, and 6 hours or so total build. I love the prinsu racks and such, but they are pricey and this allows me to tinker a bit.
09-01-2021, 08:42 PM
Thanks for the reply.!!
Can't wait to see what you have come up with. I found some OEM tracks from a junked truck. so this will be a direct replacement. I do like the idea of a little heavier duty track though.
Currently 194K
Cheers
09-01-2021, 11:44 PM
Sweet. Always good finding oem parts at the yard.
09-02-2021, 12:50 PM
So far this makes the front wiper motor and the Tracks are from a junky.
Oh well. it serves a purpose.
Currently 194K
Cheers
09-02-2021, 06:38 PM
As someone who installs track on a regular basis, be mindful that
beefier track no longer becomes the "fuse" in the system and can
potentially cause the roof itself to get damaged or torn...
Much easier to simply replace cheap track!
Build Etc...
If it ain't broke, fix it 'til it is.
09-02-2021, 08:08 PM
That also makes pretty good sense.. I wouldn't be happy if my roof peeled up.. Nope... not happy at all.
Currently 194K
Cheers
09-02-2021, 08:10 PM
Which would you use if you couldn't find a track from the junky? something from E trailer? they had solutions also.
Currently 194K
Cheers
09-02-2021, 08:11 PM
I attached the unistrut to the factory tracks for this roof rack build. I used the 1 5/8" for that section and essentially used it as side rails to maintain a low profile design. The cross bars are all the 13/16" unistrut to save weight and keep it low profile.
Two things I am conscious of during this build are, the fact that the unistrut it a little heavier than the cheap dorky roof baskets people use for a roof rack, and as mentioned just because the new bars I installed can support alot more weight doesn't mean the factory tracks can.
I don't plan on putting alot of weight up there anyway. I used the unistrut for its durability, versatility, and low profile design.
09-02-2021, 08:16 PM
All i need is Track and the Thule system will do the roof. Unistrut is pretty good stuff Nice n solid. Sounds like you have made a good decision.
Currently 194K
Cheers
09-02-2021, 08:47 PM
How much, if you don't mind me asking?
2017 TRD Off Road
