User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 08-30-2021, 11:10 AM #1
giguchan's Avatar
giguchan giguchan is offline
Senior Member
giguchan will become famous soon enough
Senior Member
giguchan's Avatar
Roof Rails replacement
All,
As the Title says... I need to replace my Roof Rails. These are the Rails that run from the front to the rear of the Vehicle. Does anyone know of any aftermarket Rails that i might use?
I had my Thule gear on the roof when i hit a low hanging limb. The thin lips of the rails ripped up. Good thing they were empty.
I can always just RE mount the Thule racks to a non damaged area, but the Manufacturer recommends specific distance apart to maintain structure integrity.
Thanks.
__________________
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 08-30-2021, 11:18 AM #2
spartacus's Avatar
spartacus spartacus is offline
Senior Member
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
Senior Member
spartacus's Avatar
Quote:
Originally Posted by giguchan View Post
All,
Thanks.
Rhino-rack makes rtc style roof tracks channel mount in different lengths.
spartacus is offline   Reply With QuoteReply With Quote
Old 08-30-2021, 12:16 PM #3
giguchan's Avatar
Senior Member
Senior Member
giguchan's Avatar
Thank you
I'll have a look see and see what they have that might suit me..
__________________
Currently 194K
Cheers
Old 08-31-2021, 09:43 PM #4
Thepedigree13 Thepedigree13 is offline
Member
Thepedigree13 is on a distinguished road
Member
You could use unistrut and build your own. It's like 25 dollars for a 10 foot long piece.
I just built a roof rack using it, and I really like it alot. I'm about 100 dollars total into my build and it's coming together very well.
It's low profile, heavy duty, versatile, and basically an erector set for adults when it comes to putting it together.
__________________
2016 TE (WIFES)>Stock with KO2's, SW sliders
2001 Sport (MINE)>FJC front coils/C59-137 rear 5100's, 265/75r16 g003
2013 Mazdaspeed3 (MINE)> bolt ons and tune
Thepedigree13 is offline   Reply With QuoteReply With Quote
Old 08-31-2021, 10:50 PM #5
giguchan's Avatar
Senior Member
Senior Member
giguchan's Avatar
Thanks for the reply!
I'd love to see what it looks like when your project is completed.
I'm going to look into that.
__________________
Currently 194K
Cheers
Old 08-31-2021, 11:26 PM #6
Member
Member
I'll post photos when it's complete.
I threw it together one night before a river trip, just so I'd have a way of attaching a much needed awning in this TX heat.
It comes galvanized, which is cool for corrosion resistance, but sucks if you want to paint it. They make all types of fittings for them, but I also like that you can bolt anything you want to them, by virtue of the predrilled holes they have.
When the weather cools down I'm going to take it off and paint it properly.
I made 4 more cross rails that are prepped and primed, ready to paint. Waiting on the humidity to lower before painting those. There will be a total of 6 cross rails, spaced about 12 inches from each other.
The first two that are currently on there stick out 6 inches from the main rails/tracks on both sides to allow the awning to protrude out where I wanted it.
As for the other 4 cross rails that aren't installed yet.
I used 30% vinegar to clean them, then scuffed them. Then I sprayed them with a solvent based paint prep aerosol. Then primed them with acid etching primer. Took about an hour. The primer appears to have adhered pretty well.
Anyway, all in all I think I'll end up spending $150-200 total, and 6 hours or so total build. I love the prinsu racks and such, but they are pricey and this allows me to tinker a bit.
__________________
Old 09-01-2021, 08:42 PM #7
giguchan's Avatar
Senior Member
Senior Member
giguchan's Avatar
Thanks for the reply.!!
Can't wait to see what you have come up with. I found some OEM tracks from a junked truck. so this will be a direct replacement. I do like the idea of a little heavier duty track though.
__________________
Currently 194K
Cheers
Old 09-01-2021, 11:44 PM #8
Member
Member
Sweet. Always good finding oem parts at the yard.
__________________
Old 09-02-2021, 12:50 PM #9
giguchan's Avatar
Senior Member
Senior Member
giguchan's Avatar
So far this makes the front wiper motor and the Tracks are from a junky.
Oh well. it serves a purpose.
__________________
Currently 194K
Cheers
Old 09-02-2021, 06:38 PM #10
GhostRing's Avatar
GhostRing GhostRing is offline
Member
GhostRing will become famous soon enough GhostRing will become famous soon enough
Member
GhostRing's Avatar
As someone who installs track on a regular basis, be mindful that
beefier track no longer becomes the "fuse" in the system and can
potentially cause the roof itself to get damaged or torn...
Much easier to simply replace cheap track!
__________________
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 08:08 PM #11
giguchan's Avatar
Senior Member
Senior Member
giguchan's Avatar
That also makes pretty good sense.. I wouldn't be happy if my roof peeled up.. Nope... not happy at all.
__________________
Currently 194K
Cheers
Old 09-02-2021, 08:10 PM #12
giguchan's Avatar
Senior Member
Senior Member
giguchan's Avatar
Which would you use if you couldn't find a track from the junky? something from E trailer? they had solutions also.
__________________
Currently 194K
Cheers
Old 09-02-2021, 08:11 PM #13
Member
Member
I attached the unistrut to the factory tracks for this roof rack build. I used the 1 5/8" for that section and essentially used it as side rails to maintain a low profile design. The cross bars are all the 13/16" unistrut to save weight and keep it low profile.
Two things I am conscious of during this build are, the fact that the unistrut it a little heavier than the cheap dorky roof baskets people use for a roof rack, and as mentioned just because the new bars I installed can support alot more weight doesn't mean the factory tracks can.
I don't plan on putting alot of weight up there anyway. I used the unistrut for its durability, versatility, and low profile design.
__________________
Old 09-02-2021, 08:16 PM #14
giguchan's Avatar
Senior Member
Senior Member
giguchan's Avatar
All i need is Track and the Thule system will do the roof. Unistrut is pretty good stuff Nice n solid. Sounds like you have made a good decision.
__________________
Currently 194K
Cheers
Old 09-02-2021, 08:47 PM #15
zzdocxx zzdocxx is offline
Member
zzdocxx is on a distinguished road
Member
How much, if you don't mind me asking?
__________________
2017 TRD Off Road
zzdocxx is offline   Reply With QuoteReply With Quote
Reply
Tags
good , rails , ripped , roof , thule
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Roof Top Tent and Roof Rails RoofRack 3rd gen T4Rs 1 12-09-2020 03:54 PM
Yakima Roof Basket to roof rails decker1 4th Gen T4Rs 7 05-18-2016 01:12 PM
Roof rails Red October 3rd gen T4Rs 4 01-26-2015 12:34 PM
WTB 5th Gen SR5 Roof Rails AKLA98 Want to Buy/Trade 0 09-24-2014 12:01 AM
Changing SR5 roof rails to Trail roof rails Rocketegg 5th gen T4Rs 0 08-20-2012 04:50 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
