Originally Posted by Brian.
I had Thought that as of 2001, all the 4runners had transponder keys. But there have been surprises before with regards to keys, if Any would have a basic key it would be the SR5.
It's not really possible to Remove the immobilizer as it's integral to the body ECU (box that lives behind the glovebox). About the only way I can think to defeat it would be to take the ring that sends/receives the signal and fasten a chip/old key to it, tucking it up out of the way. Not sure if that ring is visible/part of the trim or not. Similarly, I don't believe any aftermarket Alarm system would touch that system... no real point (it's a simple comparison of the number on the key to what's stored on the ECU).
Are you sure the copy you had made wasn't a Clone? Did they drop the 2 keys into a couple cups on a electronic device? And did you pay more than about $15?
*EDIT*
Looks like there would be the SECURITY word (and light) just to the right of the rear window switch if you have the Immobilizer/transponder key, on the plastic that shows the passenger airbag wording/light.
The key was not expensive, just a few bucks I think, so not special.
I'm convinced now that it never had the transponder, which I'm glad for; less hassle to deal with.
Thanks for the info.
