Originally Posted by Vansnxtweek
9 months almost to the day the BX Built headlights have arrived at my house. Leaving work here soon to check them out. Video in the works....
For full transparency - mine ended up getting delivered on November 27th.
So 9m5d from the order. Very similar.
As most have said, they're well worth the wait and lightyears better than the OEM setup. I just would've been better prepared to wait the 9months if it weren't initially 6 weeks... but its all good.
I didnt get anything crazy I don't really go for halos or RGB crap. I just wanted clean retrofits - and these do not disappoint.
The cutoff line is so crisp that I have not been able to get a completely seamless line between both sides, but its pretty damn close.
I found that I had to use vice grips and gently move the entire bulb assembly versus the adjustment screws to really level them out and then was able to use the adjustment screws for the height of the cutoff lines.
If you haven't already - cut the DRL wire so that they're not on all the time.
Good luck with the install.
