01-02-2022, 10:37 AM
#31
I went to visit these guys in July and let me tell you that they were slammed. Orders up the ying yang. They do great work (seen it up close and personal). I was going to order small stuff for my truck, but when he told me what the ETA was, I buckled.
Busmup808 all day, all night!
01-02-2022, 11:53 PM
#32
One year?????? Thats bonkers…..
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
01-03-2022, 12:42 PM
#33
Real Name: Patrick
Real Name: Patrick
Anyone know how long it would take to get their retrofit DIY kit? Actual real time experience and not just what their website says?
01-03-2022, 03:05 PM
#34
Originally Posted by Skulking
I've had mine waiting to be installed for a while now, and finally got around to it yesterday. I have a couple of questions for you or anyone else who has installed them. Now that I have them in, I've noticed that the new lights don't have the same shape as the old one's and poke out past the corner lights rather than the smooth curve of the old ones which matched with the corner lights. Has anyone else had this problem?
Also, I'm curious about cutting the DRL wire as I've found that mine are on fully all the time, but I can't figure out which is the DRL wire. I've actually pulled the DRL fuse and they still come on as DRL's.
Edit: I've gone out and stared at them more, and I think the difference is all in my head and the shape is the same. I'm still curious about the DRL wire though.
To follow up and answer my own question, after you install the BXBuilt headlights, if you don't want them to turn on all the time because your daytime running lights are triggering them on turn on, all you need to do is disconnect the DRL resistor. It is a roughly 2 inch metal box pretty close to the front of the drives side inner fender well next to the battery. It has a 2 pin connector on it, and if you disconnect that connector the lights will only turn on when you turn on the headlight switch instead of as soon as you release the parking brake.
01-03-2022, 03:17 PM
#35
I can't even begin to explain the troubles I had getting mine lined up well. Just finally got them pretty good yesterday. I had a huge gap between the headlight and the trim panel on the grill side and I kept trying to adjust them but couldn't get them to do what I wanted. I finally swapped the old headlight buckets/frames/backing plates, whatever you want to call the black part that actually mounts to the truck, from my old TYC headlights including their adjustment hardware and it now all lines up. The others were also super loose within these housings and swapping made it all tight. I don't want to say this is required but it got me set up correctly. Take the inner adjuster and just about back it all the way out to where you barely see any threads showing, then get 25ft. back from a wall and adjust the lower adjuster to get your height right. Once you get these to the right spot the headlight housing should be decently close to where it should be relative to the trim panel and the grill. Hopefully that helps.
01' SR5
YouTube: I make 3rd Gen 4Runner videos..among others...
https://www.youtube.com/c/TheChapMX/featured
01-03-2022, 03:51 PM
#36
My order was placed Mar 19, 2021, latest email to them they stated my order will ship no later than the end of January.
1997 3.4l w/ locker: Radflo 2.5 w/ adjusters front, OME 861 rear with LC shocks, 265/70R17 BFG KO2, TJM front bumper, 4x innovations rear bumper, 4x innovations sliders, Prinsu roof rack, ARB 2500 Awning
01-03-2022, 04:47 PM
#37
Ouch! I wish I knew this, as I placed an order 11/15, and they confirmed 18-22 week lead time, which is a worst case of 4/18. Hope they come close to that!
2000 Limited: Toytec Superflex, 255/85-16, Lil Skips gas tank skid, SaVage rear bumper and skids, BAMF Sliders
2006 SR5: FJC Coilovers +2", Toytec Superflex, 255/85-16
Sold: 2017 TRD OffRoad Prem (this rig was too nice for me!)
01-03-2022, 04:53 PM
#38
Real Name: Jase
Real Name: Jase
I waited around 4 months for my DIY retrofit kit order. They are slammed. Also at the time I was waiting for my order, I was told that a business doing renovations next door to them cut their server lines that put them down for quite some time. I would assume the DIY kits would ship faster than the ones they build. Should prob confirm.
I received my order before Christmas though and they've been very responsive. I'd buy again, just have to keep your lead time expectations in check. Quality seems to be good! Also, the price on the DIY kits is very appealing.
01-04-2022, 07:40 AM
#39
I would recommend the DIY kit being it looks pretty simple and the ones I got are scratched on the inside. Want it done right in a timely fashion, do it yourself.
01' SR5
01-04-2022, 10:04 AM
#40
I've thought about the DIY kit myself. I guess for anyone who purchased the DIY kit - share your experiences. I'd be interested in the kit for a few projects other than my T4r to retrofit them, because it is a good product IMO.
2001 SR5 | 275K+ | 3" Toytec Ultimate Coils | SPC UCA's | MotegiMR150 17x8.5 + Yoko Geo 295/70/R17 | 4Xi full drivetrain skids | OCD sway bar links F&R | Powerstop TBU | Opt OR Upper & Lower rear arms | MF Overland Exhaust | Retrofit LEDs | Vivid Lumen Fogs | Full Prinsu Rack | Front bumper retrofit/fat lip delete
1983 Pickup SR5 | 93K | LCE Street Headers | 31x10.5 BFG K02's, Full Desmog and Otherwise Original
1981 Pickup SR5 longbed | 142K |
01-04-2022, 10:16 AM
#41
My experience with the DIY kit:
https://www.toyota-4runner.org/3598234-post400.html
01-05-2022, 10:11 AM
#42
Although there are already a few..I am working on a YouTube video covering all of this.
When I first got them in I couldn't get them adjusted right at all and they were literally loose within the backing frames. I changed out the hardware and frames from my old TYC lights and found them to be much better. Was this required? No, I don't think so, but I knew they would be solid and I had them, so I did it. Mainly, I think the spring in the frames they sent were too long. Once you horizontally align them to where they should be it should have tension on the springs so this may have been my issue but at first, they were floppy and loose.
I also think the adjuster style of the TYCs is far superior so that motivated me to swap everything.
I had to rotate both the projectors within the housing and the drivers side is still not perfect but it is hitting some stop of some sort and I can't get it to rotate any further. I'm happy with where it is.
Overall after a few days of tinkering and messing around, I'm extremely happy with them. I was pretty aggravated for awhile but I am happy now that everything is good.
Now I just wait for the halo controller and the corner lights. In the mean time I just ordered some black corners that were readily available off eBay...
01' SR5
01-11-2022, 01:35 AM
#43
In the same boat, placed order mid March 2021 and kept getting the ship date pushed back then the last email I got was no later than the week of the 3rd in January....still waiting tho.
01-20-2022, 10:28 AM
#44
Ordered mine early Sept, with a 12 week build time. Nothing arrived. I contacted them and was given the normal excuses and told it would ship no later than Jan 10th. Still nothing.
They are good at answering emails, but not good at proactively keeping customers informed when they fail to deliver as expected. That's the frustrating part. When you're out this kind of money for something, it's not unreasonable to expect basic order updates.
01-20-2022, 02:25 PM
#45
Ordered a DIY retrofit kit on black Friday and it just shipped. Just a hair over their estimated wait time.
97 Limited, 5100’s, OME 883/891, Built Right UCA, Custom Sliders, coastal off-road front bumper, 4x innovations rear bumper(custom built swing out), 4.88 gears, Circuit Offroad 17x8.5 wheels, Kenda Klever RT 35x10.5r17
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
