Old 08-31-2021, 05:17 PM #1
SasquatchRevenge's Avatar
SasquatchRevenge SasquatchRevenge is offline
SasquatchRevenge is on a distinguished road
Toytec Boss 2.0 Aluma Coilover Orientation
Good afternoon!
Last night I installed a fresh pair of Toytec Boss 2.0 Aluma Series coilovers to replace my old, worn boss set. Before installation, I called over to Toytec to make sure these parts were not side specific. The rep advised they were not side specific, I just needed to install so the Toytec logo was facing outward. I installed the driver side first, and the bottom mount needed a fair amount of turning to line up. Not a big deal, I've read that is expected. The Toytec logo and top of the shock body where it connects to the top mount ended up being slightly angled in relation to the UCA and the vehicle. At this point, I didn't think too much about it and moved on to the passenger side. On the passenger side, the unit slid right in, the toytec logo and top mount were dead nuts center. The bottom mount required very minimal adjustment to get in line (maybe a couple millimeters of turning). I then noticed that the outer top mount bolts did not match from passenger to driver side. The passenger side top mount outer bolt (which seemed to fit "better") utilized the center of the 3 bolt holes, while the driver side (which is angled) utilized the first bolt hole. My inner peace is being greatly disturbed by these not matching up from side to side! I have confirmed that the holes on both coilover top mounts were identical prior to installation (see attachments for visual aid)
My question is: does this matter? Why/how could this happen?
Thanks in advance!
Toytec Boss 2.0 Aluma Coilover Orientation-coilover1-jpg  Toytec Boss 2.0 Aluma Coilover Orientation-coilover2-jpg  Toytec Boss 2.0 Aluma Coilover Orientation-coilover3-jpg  Toytec Boss 2.0 Aluma Coilover Orientation-coilover4-jpg  Toytec Boss 2.0 Aluma Coilover Orientation-coilover-pass-side-close-up-jpg  Toytec Boss 2.0 Aluma Coilover Orientation-coilover-driver-side-close-up-jpg  Toytec Boss 2.0 Aluma Coilover Orientation-coil-prior-install-jpg
"When you don't know what you're doing, it's best to do it quickly"
-Jase Robertson
SasquatchRevenge is offline   Reply With QuoteReply With Quote
Old 09-01-2021, 11:21 PM #2
Bumping this. Hopeful someone familiar with these coilovers can help out
-Jase Robertson
Old 09-07-2021, 01:57 PM #3
Ruiner's Avatar
Ruiner Ruiner is offline
Ruiner is on a distinguished road
Ruiner's Avatar
pretty sure they are side specific
Ruiner is offline   Reply With QuoteReply With Quote
Old 09-07-2021, 02:08 PM #4
Ruiner's Avatar
Ruiner's Avatar
NOTE: IF COIL SPRINGS ARE MARKED WITH AN A OR B. A IS DRIVER SIDE AND B IS PASSENGER
SIDE. SPACERS: The spacer goes above the coil spring.
per the instructions
Old 09-07-2021, 02:16 PM #5
Ruiner's Avatar
Ruiner's Avatar
I want to say its etched into the top of the mount that bolts to the car, so you will, unfortunately, have to remove the Coilover to see.
mount , passenger , side , top , toytec
Anyone Running Toytec Boss 2.0 Front Aluma Series Coilovers? brian2sun 3rd gen T4Rs 26 10-31-2021 09:15 PM
285/75/16 on Toytec Aluma Boss 2.0??? ccampbell01 3rd gen T4Rs 13 07-17-2021 01:34 PM
Toytec Aluma Boss 2.0 FACELIFT ccampbell01 3rd gen T4Rs 1 05-20-2021 11:21 AM
Help with installing Toytec Boss Aluma 2.0 on KDSS 4Runner Kyle B Engines / Suspension / Wheels / Tires / Audio / Accessories 4 05-08-2020 04:30 PM
Toytec Aluma Series Boss Kit MOONMAN5 5th gen T4Rs 2 08-24-2019 10:26 AM
