Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 01-09-2012, 01:20 AM #1
4Running Daily's Avatar
4Running Daily 4Running Daily is offline
Real Name: Connor
4Running Daily will become famous soon enough
Real Name: Connor
4Running Daily's Build Thread
Now as of 03/26/15
Connor aka 4Running Daily’s Build Thread
DSC_0111 by Connor Rhoades, on Flickr
Personal info: I’m 19. I'm originally from Escondido, CA, but I'm currently studying Mechanical Engineering at ASU in Tempe,AZ. 4Running Daily is my username because it is my Daily Driver currently.
My Runner:
History: Dad leased it new, and then bought it with the intentions on me driving it to high school (successful). He took it up Black Bear Pass in Colorado, all stock. It was stolen out of my garage and was found about 16 hours later full of Candy and a printer that wasn’t mine.
Black Bear Pass in 1996
Washing it when I was 3
When I got it
Typical Stuff:
1996 Toyota 4Runner SR5 4x4
Evergreen Pearl with Blue/Grey Interior
5 Speed
155k miles
Terrible Clear Coat
4Running Daily's Build Thread-old-jpeg
4Running Daily's Build Thread-clear-coat-jpeg
4Running Daily's Build Thread-new-jpeg
After a Few $$ and some blood, sweat, and tears
Mileage:
202,500 miles
Mods:
Re-Painted Evergreen Pearl
Toytec Front Coilovers (Replaced)
Superflex Rear Springs (Replaced)
Deckplate Mod
Alpine ILX-007 Headunit
Ferrari Leather Shift Knob
LC80 Wheels in Bronze
Borla Muffler
ARB Compressor
Yukon Grizzly Zip Air Locker
315/75/16 Goodyear MTR's
Savage Off-Road Sliders
Savage Off-Road Front Bumper
Savage Off-Road Full Skid Plates
Camburg Uni-ball Upper Control Arms
Any7 Off-Road Gas Tank Skid
Toytec Rear Adjustable UCA's
Custom Rear Adjustable LCA's
Wheeler's Front Superbumps
Big 3 Upgrade
Icon 2.5 rear shocks with piggyback Resi
Savage Off-Road Rear Bumper with Swing-out
ADS 2.5 Coilovers with Reservoirs
LC 8 Wraps in the Rear
Maintenance
-02/02/12 New Rear Drum Brakes
-03/31/12 Repainted Evergreen Pearl
-05/12/12 157,299 miles New front rotors
-07/26/12 158,623 New Clutch Master Cylinder and Slave Cylinder
-159,500 New Toyota Fuel Filter
-159,500 Oil Change with Toyota Oil filter
-159,500 New Toyota PCV Valve
-159,500 All new fluids in both differentials, the transmission, and transfer case
-159,500 New air filter
-159,500 New Borla XR-1 Muffler
-159,500 Spark plugs and wires replaced with new NGK ones
-159,500 Throttle Body and MAF cleaned
-162,500 Oil Change with Toyota Oil Filter
-163,684 New Front Brake pads
-164,444 Newly rebuilt passenger head installed and new head gaskets
-165,400 New Air Filter
-167,362 New Starter Contacts and Sunroof Motor
-05/29/13 New Power Steering Pump Bearing/Seal and fluid flush
-07/23/13 New Suspension
-07/27/13 New Tires
-07/29/13 New Clutch Master Cylinder
-168,500 Oil Change
-168,600 Alignment at The Truck Shop in Miramar
-169,000 Tire Rotation
-169,000 New Rear Main Seal
-169,000 New Flywheel
-169,000 New shifter bushings
-169,000 New clutch disc
-169,000 New pressure plate
-169,000 New pilot bearing
-169,000 New release bearing
-172,000 New Hella Horns
-172,000 New Front Sway Bar Bushings
-172,220 Oil Change
-172,562 New Outer Tie Rods
-172,562 Reman'd Power Steering Rack
-172,562 Power Steering Fluid Flush
-172,562 Alignment
-173,148 Coolant Flush
-173,148 Thermostat and T-Stat Gasket Installed
-175,000 Rear Hatch Lift Struts Replaced
-175,500 New Toyota Lower Ball Joints installed
-175,500 Used Camburg Uni-Ball Upper Control Arms Installed (8,000 miles old)
-175,900 Oil Change
-175,900 Tire Rotation
-177,154 Engine #2 Installed
Mileage of Engine #2 on time of install 92,000 miles
New Toyota Genuine Parts installed at install of Engine #2
-6 Rebuilt Injectors
-Water Pump
-Thermostat and Gasket
-Timing Belt
-2 Timing Belt Idler Bearings
-6 Spark Plugs
-2 Camshaft Seals
-2 Crankshaft Seals
-Oil Filter
-Release Bearing
-Valve Cover Seal Washer
-6 Spark Plug Seals
-2 Valve Cover Gaskets
-PCV Valve and Grommet
-3 Belts
-Oil Pan
-178,250 Safari Steering Rack Installed
-178,250 Power Steering Fluid Flush
-178,250 Alignment
-180,000 Air Filter
-180,500 Diehard platinum Battery installed
-181,800 Alignment
-182,288 Oil Change
-182,288 Coolant Bypass Pipe
-185,555 Brakes bled
-185,555 Oil Change
-186,700 Tires Balanced
-188,400 New Front diff oil
-188,400 New Driver CV Axle
-188,400 4 New Toytec Coilover bushings
-190,000 ADS Coilovers Installed
-191,600 Alignment
-192,000 New Air Filter
-192,000 Oil Change
-192,000 Re-sealed Rear Diff
-193,000 New Brakes
-195,000 New Rear Axle Seals
-195,000 New Rear Wheel Bearings
-195,000 New Rear Brakes
-195,600 Tires Balanced and Rotated
-196,900 New Front Brakes
-196,900 Total Chaos Spindle Gussets Installed
-196,900 New Lower Control Arm Bushings
-196,900 New Front Wheel Bearings and seals
-196,900 Alignment
-200,000 Air Filter
-200,800 Tires Rotated and Balanced
-201,300 Oil Change
-201,300 OEM CV's rebuilt and installed
-201,300 New Front Diff Oil
-201,300 New Front Diff Output Seals installed
-201,800 New Flywheel
-201,800 New Clutch
-201,800 New Throwout Bearing
-204,000 Rebuilt OEM Starter
-205,738 Tire rotation and balance
-205,738 New OEM spark plugs
-205,738 Cleaned TB
-205,738 Installed Oil Catch Can
-205,738 New NGK Spark Plug Wires
-206,380 Oil Change
-213,100 Oil Change
-215,000 New Steering Rack
-215,000 New Power steering pump
-215,000 Alignment
-216,500 New Radiator
-216,500 Alignment
-222,500 Oil Change
-222,500 Diff Oil
-222,500 Air Filter
The Best Off-Road Companies in the Game:
-Roy @ Savage Off-Road
-Micah @ DownSouth Motorsports
-Brian @ ADS Racing Shocks
Recent video:
Recent photos:
DSC_0201 by Connor Rhoades, on Flickr
DSC_0207 by Connor Rhoades, on Flickr
DSC_0204 by Connor Rhoades, on Flickr
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner View Post
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
4Running Daily is offline   Reply With QuoteReply With Quote
Old 01-09-2012, 01:59 AM #2
James Perez James Perez is offline
James Perez is on a distinguished road
Personal info: I’m 15 first of all. I get my license on July 17th, 2012. I’m a pretty serious mountain biker, that’s how I normally get from point a to point b. I live in Escondido, Ca. 4Running Daily is my username because it will be my Daily Driver once I get my license.
Family Cars: 2011 BMW X5 Diesel, 2006 BMW 330i, 1990 Porsche Carrera 2 Cab
My Runner:
History: Dad leased it new, and then bought it. He took it up Black Bear Pass in Colorado, all stock. It was stolen out of my garage and was found about 16 hours later full of Candy and a printer that wasn’t mine. I have woken up in the morning to it being covered in Toilet Paper 6 times now.
Typical Stuff:
5 Speed (No E-Locker, yet?)
155k miles
The Clear Coat is bad, just makes me sad every time I look at it.
What Has Been Done
OME lift kit
Painted Stock 16” Spilt Spoke Wheels (Painting the Rims)
Painted Spoiler
Removed front bumper dent, kinda. (Replacing a big dent with a bunch of small ones)
I was sick of my power antenna so I took the motor out, took the mast holder out of that, put the mast holder back in the car, take the antenna flip it upside down fully extended, put some glue in there, put the mast back in, and boom, free non power antenna. Best part, I can just take it out and put a large nail in there when off-roading.
I have Firestone Destinations 265/70/16 sadly. (I hate you Firestone)
Kenwood DXP308u I love it.
Skull Shifter
Here are some Pictures
Nice man!
James Perez is offline   Reply With QuoteReply With Quote
Old 01-09-2012, 05:46 AM #3
SJC's Avatar
SJC SJC is offline
SJC is on a distinguished road
SJC SJC is offline
SJC's Avatar
Oh god, that clear coat
Nice runner though, free candy? Awesome
3.4 Swap. Sas. Locked front/rear. 5:29's 35x1250 KM2's
SJC is offline   Reply With QuoteReply With Quote
Old 01-09-2012, 10:26 AM #4
Stick Figure's Avatar
Stick Figure Stick Figure is offline
Stick Figure will become famous soon enough
That clear coat makes me glad I occasionally pull the roof rack and do a full wax job on mine. Still about a million % better than what I was driving at your age though.
Stick Figure is offline   Reply With QuoteReply With Quote
Old 01-09-2012, 10:42 AM #5
tv4184 tv4184 is offline
tv4184 will become famous soon enough tv4184 will become famous soon enough
Nice canvas to start off with.
1999 2.7 5MT - SOLD // 2007 V8 4WD - Gone
2011 FJ 4WD - to new beginnings
// 4G V8 // 3G 2.7 5MT // Model 3 // IS300 5MT // FD RX7 //
tv4184 is offline   Reply With QuoteReply With Quote
Old 01-10-2012, 12:56 AM #6
Real Name: Connor
Real Name: Connor
I just realized that non of my links work, I'll fix that.
Old 01-17-2012, 08:45 PM #7
Real Name: Connor
Real Name: Connor
Got lazy and haven't fixed my links yet, maybe eventually.
I got my Permit today! Woo. 6 months from today I can get my license.
Old 01-17-2012, 09:23 PM #8
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
Man, I really don't miss those days lol. Although being 25 there's way more responsibilities. Before it was just "who's got the reefer" and "who's buying the booze this weekend?"
Oh, and almost forgot. Nice whip! x2 on it being a way better vehicle than my first one.
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 01-17-2012, 10:11 PM #9
A.Wilson013's Avatar
A.Wilson013 A.Wilson013 is offline
Real Name: Alex
A.Wilson013 will become famous soon enough
Real Name: Alex
Bahaha, the good ol' days.
I was just thinking about the other day. I wish I would have realized how good I had it.
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
A.Wilson013 is offline   Reply With QuoteReply With Quote
Old 01-17-2012, 10:31 PM #10
PitbullRescuer's Avatar
PitbullRescuer PitbullRescuer is offline
PitbullRescuer is on a distinguished road
25? Lucky you. It's all down hill from there my friend.
'98 SR5 4x4, cheap DD http://www.toyota-4runner.org/3rd-ge...im-addict.html '99 SR5 Highlander 4x4/5 Speed... http://www.toyota-4runner.org/3rd-ge...eed-build.html '97 SR5 4x4/5 speed, another new project... http://www.toyota-4runner.org/3rd-ge...new-build.html '00 SR5 4x4, new project, stay tuned... http://www.toyota-4runner.org/3rd-ge...ld-thread.html '97 Limited 4x4, freshened up quite a bit... http://www.toyota-4runner.org/3rd-ge...d-3rd-gen.html '99 SR5 Highlander 4x4... http://www.toyota-4runner.org/3rd-ge...ce-thread.html
PitbullRescuer is offline   Reply With QuoteReply With Quote
Old 01-21-2012, 10:05 PM #11
Real Name: Connor
Real Name: Connor
Here's the top door jam.
4Running Daily's Build Thread-top-door-jam-jpeg
Old 01-26-2012, 12:56 AM #12
Real Name: Connor
Real Name: Connor
Finished my grill
4Running Daily's Build Thread-beast-jpg
Old 01-26-2012, 04:40 AM #13
masphx's Avatar
masphx masphx is offline
Real Name: Mason
masphx is on a distinguished road
masphx's Avatar
Real Name: Mason
Paint a wide flat black 'racing stripe' down your hood and roof. Will cover thoske paint issues a might look kind of cool. Just an unconvential thought that might look kind of cool.
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
masphx is offline   Reply With QuoteReply With Quote
Old 02-05-2012, 09:46 PM #14
Real Name: Connor
Real Name: Connor
My drum breaks are seized up so I'm 80% sure I will begin a disk brake conversion next weekend. This should be exciting.
Old 02-07-2012, 10:58 PM #15
Real Name: Connor
Real Name: Connor
Well until I decide to do a disk brake conversion, I got the drums fixed. replaced some hardware, new pads obviously, and a few others = 250 out the door.
The 4runner drives 1000 times better then before, these brakes have been stuck for probably two months. It's so much better I can't even express it. Hopefully my gas mileage gets better now. It was at 13 earlier this week.
shaggy and scoob , wood decks with a view
Build Thread josh.bunch 3rd gen T4Rs 105 11-19-2023 12:48 PM
The Turbo Rock Lobster steezemcqueen 3rd gen T4Rs 538 04-19-2023 11:04 PM
$300 Buy build thread apache2831 Classic T4Rs 10 06-28-2011 04:07 PM
Another Daily Driver Build Thread! Pictures galore. Patsawasy 3rd gen T4Rs 41 08-08-2010 09:03 PM
