Old 08-31-2021, 06:29 PM #1
DenverAirport's Avatar
DenverAirport DenverAirport is offline
DenverAirport will become famous soon enough
Cranks fast when hot, skips.
Hey guys. When my engine is hot (say I'm at a gas station, turn the engine off to fill up and then start the engine again) it will crank over quickly and make a faster, sputtering sound. Sometimes it will sound like it's skipping in the process. It always starts (knock on wood) but the speed of it almost made me question if there was a leaking injector or something?
Could this be a potential sign of starter failure? I'm considering ordering a rebuild kit (or a reman with the higher wattage option) as the starter looks dirty as hell and I imagine the contacts won't necessarily last forever (haven't been replaced and now at 250k miles.)
Here's a video of the sound, not the easiest thing to hear but may give some reference.
IMG 5516 - YouTube
97' Limited - 250k - Stolen & Found - 4WD, 3" Billstein 5100 lift with OME 881, 890 springs, Diff drop, Camburg UCA's, 231mm TBU, Tom Wood's driveshaft, eimkeith PCK, Champion radiator, Ultraguage
99' SR5 "Highlander Edition" - 277k - Build thread soon - 4WD, Factory rear locker and 1" lift
DenverAirport is offline   Reply With QuoteReply With Quote
Old 08-31-2021, 09:35 PM #2
spartacus's Avatar
spartacus spartacus is online now
spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold spartacus is a splendid one to behold
spartacus's Avatar
IMG 5516 - YouTube
Sounds like a good start to me. Its not buzzing or screeching or clicking. Rebuilding starter is good practice and part of maintenance.
spartacus is online now   Reply With QuoteReply With Quote
Old 09-01-2021, 02:27 AM #3
HiLife HiLife is offline
HiLife is a jewel in the rough HiLife is a jewel in the rough HiLife is a jewel in the rough
Sounds like a good normal start for me too.
Old 09-01-2021, 10:42 AM #4
alumarine alumarine is offline
alumarine will become famous soon enough alumarine will become famous soon enough
If the motor is rotating normally while trying to start it's not the starter.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 09-01-2021, 12:14 PM #5
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a name known to all Devbot is a name known to all Devbot is a name known to all Devbot is a name known to all Devbot is a name known to all Devbot is a name known to all
Devbot's Avatar
Real Name: Devan
Sounds normal to me
Y2K Highlander Millennium Silver 3.4L auto @ 300k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / EimKeith PCK / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / CBI Hybrid Bumper + Tire Carrier / 4xInnovations Sliders / Smittybilt XRC Gen 3 Comp. / Opt Offroad Trailing Arms / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
Old 09-01-2021, 05:23 PM #6
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of gamefreakgc has much to be proud of
Real Name: Jerod
I didn't hear anything out of the ordinary except for that exhaust drone or whatever was going on in the background. Starting up quickly isn't a bad thing.
A bad starter will give you the opposite, a 'click' and nothing else then will start on the next try.
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 233K miles.
326WHP 347TQ
Old 09-01-2021, 09:57 PM #7
No buzzing or clicking at all. I'm going to rebuild the starter regardless for this reason -- might as well I'm going to have to do it at some point!
Old 09-02-2021, 09:33 AM #8
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is a jewel in the rough shadow247 is a jewel in the rough shadow247 is a jewel in the rough
shadow247's Avatar
Mine is the same. It starts up really quickly if I start it back up after running and being fully warmed up.
When I put a new Alternator on, it really started cranking fast. Try cleaning your battery terminals and Alternator Connection.
But everything sounds normal to me.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 11:01 AM #9
Rebuilding a starter is only part of maintenance if it needs rebuilding.
It is NOT part of regular preventative maintenance.
Old 09-03-2021, 01:44 AM #10
Good to hear this. I just replaced my alternator as well + I changed my batt and terminals at the same time. I cleaned my alternator connection when swapping but it was definitely really cruddy.
contacts , engine , hot , sound , starter
Lil' Skips Gas Tank Skid Rimcrew 3rd gen T4Rs 11 08-17-2017 06:52 PM
Nah nah nah... lil skips rocks! calicojax 3rd gen T4Rs 0 06-20-2017 11:57 PM
CD Skips alaskaman 4th Gen T4Rs 1 12-12-2013 12:03 PM
Stock Radio/Cd Player Skips A Lot anotherT4Rowner Problems & Warranty Issues 1 02-05-2009 07:23 PM
02 radio skips bad, any help?? KevGuillot Engines / Suspension / Wheels / Tires / Audio / Accessories 6 04-23-2004 05:31 PM
