09-25-2006, 07:37 PM
Real Name: Bryan
Real Name: Bryan
Anyone have trouble finding correct radio wiring harness?
I'm having trouble finding the correct wiring harness for my radio. I purchaced two so far and they're both wrong. The first one I got had two plugs, but my truck only has one connector. The second harness I got is one plug with RCA's on the radio side for the speakers, It fits the connector in the truck, but the wires don't match up with the wire locations in the truck. I know for sure someone in here has an aftermarket radio in their truck. Anybody know part numbers or anything?
2001 T4R SR5
09-25-2006, 07:43 PM
Re: Anyone have trouble finding correct radio wiring harness?
be nice to know what you drive ya know!!
99 limited millineum silver
TJM-17 with sonoran steel shackle hangers andknock off hella-500 lights from pepboys!
Satoshi mod
locker wire mod
fog light rewire mod
cobra 19ultra III with wilson tunable antenna and firestik hatch mount
trail gear sliders
jensen 9510 / basslink sub
pics
http://yotatech.com/showthread.php?t=96117
09-25-2006, 08:44 PM
The one with two plugs is the correct one! You just have to unplug the two wires from your AMP! The single wire you say you have is the single wire coming out of your AMP. Under your amp you have two wires that plug in that will fit into the adapter you bought with two plugs! I made this same mistake when I first installed my aftermarket deck. I'll see if I can't find the writeup i used that shows how.
1998 Toyota 4Runner SR5 4x4 Auto V6 3.4L, Anthracite Metallic.
09-26-2006, 07:01 AM
Real Name: Bryan
Real Name: Bryan
ok, thanks I'll look into that!
09-26-2006, 11:54 AM
If your deck has front and rearRCA outputs then you can use the harness you got with RCAs in it. Otherwise there is a small silver box behind your old radio in the dash that has 2 plugs on the bottom of it which are standard toyota plugs. You just unplug them and use the standard toyota harness to wire in.
09-27-2006, 09:33 AM
Real Name: Bryan
Real Name: Bryan
eliminated the factory amp, worked like a charm! thanks guys!
01-31-2014, 09:39 AM
4runner 1989 stereo harness problem
Hello , Before 2 days i cut stereo harness wire and bought a new one , and now i dont know how to put it , there are 8 wires , i wire it random but the hor turn on when i press 4 signals button
Plz help me how to fix that
01-31-2014, 11:15 AM
Real Name: Kyle
Real Name: Kyle
Need more info...not real sure what u r saying.
2001 LTD Dorado gold. 160,000+ miles All the goodies are in my thread below.
http://www.toyota-4runner.org/3rd-ge...-progress.html
01-31-2014, 12:32 PM
You cut the harness out? Can you provide some pics?
85 Xtracab, 3Link Front, Marlin Dual Ultimate, Double Locked on 37s
01-31-2014, 02:27 PM
This is the pic
01-31-2014, 02:31 PM
Other pic
01-31-2014, 02:41 PM
official vendor
official vendor
Not really sure what you're trying to say. But it looks like you took a knife and cut the wires in random spots. Put the harness back in by connecting the matching wires, and then buy a harness to do to job correctly. Also, it seems that this is not out of a 3rd Gen 4Runner.
01-31-2014, 02:50 PM
His is an 89 but I agree 100% with your recommendation.
x2 Reconnect the harness you cut, buy the correct harness for your radio/vehicle. If you don't know which harness to purchase you can call Crutchfield.
Crutchfield: Car Stereo, Speakers, Home Theater, LED LCD TV, Cameras
1-888-955-6000
01-31-2014, 03:54 PM
official vendor
official vendor
There's more to your harness than just those wires. Here's a diagram of what it should look like stock. Going off of this diagram you should be able to splice in your new harness.
06-21-2017, 03:34 PM
Good info!
