Old 09-02-2021, 04:43 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Squeaking coming from left rear side
My 4runner has developed a squeak and I've been trying to find what it is. When I a can hear it whenever I am going between 5-35 mph. At first I got the grease zerks on the driveshafts greased, but that didn't fix the issue.
It doesn't matter if I'm turning, going straight, coasting, or accelerating. Is there anything else I should try greasing?
Pyral is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 06:22 PM #2
spartacus's Avatar
spartacus's Avatar
pan hard bar bushings or rear uca or lca bushings could squeak.
Old 09-03-2021, 03:21 PM #3
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I was looking around and it seems that my pan hard bar (or as Toyota calls it 'lateral rod'? #3 in diagram below) is rubbing against a metal bracket. I doubt it is the cause of my squeaking because it only contacts the bracket over bumps. Very surprised this is an issue because my 4runner is not lifted, most people have this issue after doing a lift.
Any bushing in the diagram above needs to be replaced due to age. The shock bushings and sway bar bushings are already ordered.
Old 09-03-2021, 07:52 PM #4
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Is it a rotational type squeak? Could be rear brake shoes not retracting fully off the drum.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 10:20 PM #5
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Yes it is rotational. How do I check if it isn't releasing
Old 09-03-2021, 11:29 PM #6
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
FWIW for a while my panhard bar would cause a squeak and it was very easy to deduce by simply hanging on it and trying to shake it around like a gorilla. So if you couldn't get it to replicate by doing so I'd say it's pretty unlikely to be the culprit
Lateral rod/arm, trac arm/bar, panhard bar/link, 5th link - there's a few different names for them it seems
Old 09-04-2021, 02:32 AM #7
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Why is my panhard bar rubbing against its left mounting bracket though? My vehicle isn't modded and is at its original ride height, and the bar in its natural position is perfectly level like it should. Even if it isn't the original source of my issue, it is still a problem because metal on metal contact is something that is never good
All the bushings that I can see are cracked and dry rotted, makes it hard to say that one of them can't be giving me my problem.
I think I need to jack the vehicle up and turn the wheels by hand to get a better idea of what is going on with my drive line. I'll hopefully do it tomorrow
Old 09-04-2021, 04:34 PM #8
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Update: Jacked up the vehicle to turn the wheels. The brakes don't seem to be catching and everything is turning over silently (both drive shafts too). So it might not be anything relating to the drive train after all.
I also tried pushing the panhard bar to check for play. I couldn't feel any, but I was jacking off the rear axle and that might of kept it under compression and kept me from feeling any play.
Also doing sway bar bushings today. The bushings I really need to do are the ones that require me to press them out, like the panhard and the control arms. I think they are the ones most likely giving me trouble.
Is there any way to lubricate those pressed bushings without removing to see if they are the things squeaking?
1998 4runner 2.7 manual
Old 09-04-2021, 09:35 PM #9
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Not sure if you could easily check and/or re-lubricate without removing.
Could the squeaking be body mount bushings? (genuine question)
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 09-04-2021, 10:09 PM #10
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I mean it could, but I doubt it because the body mount bushings don't look as rough as all the other bushings
Old 09-14-2021, 03:20 PM #11
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Well the squeak seems to be getting worse, its really apparent at 15 mph. I cant remember having this issue before I put back on the original wheels. Is it possible that they could cause the issue?
Its definitely a rotational squeak.
Old 09-15-2021, 07:11 AM #12
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Maybe the dust shield is bent and contacting the drum slightly. I have a squeek from the rear left but from side to side motion not rotational. It's from the left parking brake I think but never been able to get rid of it.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 07:23 AM #13
The OE rubber bushing are designed to stretch/torque, they dont need lube like poly bushings (correct me if I'm wrong). I've never had rubber bushings make any noise other than a clunk when worn out.
99 SR5 v6 4WD
11 SR5 v6 4WD
driveshafts , grease , greased , issue , zerks
Left Side Wheels/Brakes/Axle Squeaking at <20mph Lolaya 4th Gen T4Rs 0 08-27-2019 10:26 PM
Squeaking noise rear passenger side poorbong 5th gen T4Rs 3 02-06-2018 09:09 PM
Front left wheel is squeaking Ironman707 Problems & Warranty Issues 1 02-07-2016 01:57 AM
squeaking sound coming from the rear right of the vehicle zu13 4th Gen T4Rs 5 08-22-2012 10:03 AM
SAGGY REAR LEFT SIDE any advises please?? jakov 3rd gen T4Rs 10 05-09-2010 12:04 AM
