Old 09-02-2021, 10:09 PM #1
psyduck psyduck is offline
psyduck is on a distinguished road
Stripped steering column bolt, any options here?
Trying to fix my sloppy steering. Has about 1" of play both ways and isn't responsive especially at highway speeds. Replaced steering rack bushings so I think I need to weld the shaft and fix that plastic ball. However when attempting to remove the steering rack I just can't get a grip on this last bolt to remove it. The allen wrench just spins after a bit of force and the next size up won't fit. Do I have any options to remove this? I am a bit limited to basic tools so I think I am out of luck...
Edit: Sorry, image got uploaded sideways for some reason.
Stripped steering column bolt, any options here?-img_1939-2-jpg
psyduck is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 11:16 PM #2
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
Use a air hammer with a bit that u can catch the edge of the bolt head to break said loose...
clearock is offline   Reply With QuoteReply With Quote
Old 09-02-2021, 11:19 PM #3
spartacus's Avatar
spartacus's Avatar
Grind down the over size Allen key gradually while testing it for a snug fit making sure not to destort the shape of the allen wrench or use the same grinder and carefully cut a deep enough slit and use a big flat screw driver.
Old 09-02-2021, 11:48 PM #4
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Torx bit does the trick sometimes. Could also try going up one size in standard sizing, assuming it's metric. Might need tapped in with a hammer to work
Allen head extractors are worth their weight in gold too
Old 09-03-2021, 07:43 PM #5
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Those things are pretty hard to snap loose from memory. Best to find a bit that fits it very snugly to avoid the slipping.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 09-03-2021, 09:28 PM #6
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Get a good quality sharp chisel for metal 1/4" to 1/2" wide.
Use the chisel at a 90 degree angle on the edge of the bolt head and give it a good hit with a hammer.
That will put a nice groove in the edge of the bolt head.
Then hold the chisel in that groove at a 45 degree angle and hit the chisel with the hammer and and turn the bolt out.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
bit , fix , rack , remove , steering
replacing intermediate steering column U joint - loose steering jrm 4th Gen T4Rs 4 09-15-2017 05:28 PM
Can't disconnect steering column from steering rack variablevalve 3rd gen T4Rs 8 05-25-2017 01:30 PM
Top hat bolt stripped help! Chubbs22 3rd gen T4Rs 3 09-30-2014 02:41 PM
Steering Wheel Alignment w/ Steering Column UncleOOPS 3rd gen T4Rs 2 07-13-2012 04:17 PM
Stripped bolt chunderboy Off Topic 7 06-04-2005 01:23 PM
