Old 09-07-2021, 11:47 AM #16
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Originally Posted by Bad Luck View Post
I didn't see you or anyone else mention lower ball joints.
Got that covered in post #3
Brian. is offline   Reply With QuoteReply With Quote
Old 09-07-2021, 02:16 PM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks! I consider lower ball joints the single most damaging missed maintenance part
Old 09-07-2021, 02:42 PM #18
Dragon_EX Dragon_EX is offline
Dragon_EX is on a distinguished road
It's definitely high on my priority list. A couple years ago the front driver side suspension got completely rebuilt after my brother smacked the wheel into a concrete barrier, but they left the other side alone so it's still all original, probably to cheap out. On the driver side you can see the LBJ all nice and new and the other side just looks sad. Probably should just get the whole front end rebuilt so at least both sides are the same.
Dragon_EX is offline   Reply With QuoteReply With Quote
Old 09-07-2021, 09:44 PM #19
Thepedigree13 Thepedigree13 is offline
Thepedigree13 is on a distinguished road
I switched over my 3rd gen to a daily driver about 2 years ago.
New plugs and wires made it feel smoother. I also change air intake filters pretty routinely. I use napa gold for those. They're affordable and seem to filter really well in this dusty southern TX area.
I also promptly replaced the radiator with an OEM Toyota one, with new hoses. My radiator wasn't bad but it was the original OD green colored one and I was afraid because of its age. I decided against an external tranny cooler, and will monitor my radiator for age/wear.
Next is bushings for me. I was under the truck last week and noticed several that are pretty bad.
If you lift your truck be ready to change out end links and cv axles, or reboot your cv axels. Mine threw grease shortly after lifting and my end links ball joints are shredded.
2016 TE (WIFES)>Stock with KO2's, SW sliders
2001 Sport (MINE)>FJC front coils/C59-137 rear 5100's, 265/75r16 g003
2013 Mazdaspeed3 (MINE)> bolt ons and tune
Thepedigree13 is offline   Reply With QuoteReply With Quote
Old 09-09-2021, 02:19 AM #20
02_SE_Runner_DAD's Avatar
02_SE_Runner_DAD 02_SE_Runner_DAD is offline
02_SE_Runner_DAD is on a distinguished road
Stick with OEM on bushings.
Fly High Son(NATE) 1995-2014
http://www.toyota-4runner.org/3rd-ge...od-thread.html
02_SE_Runner_DAD is offline   Reply With QuoteReply With Quote
Old 09-10-2021, 02:27 PM #21
It looks like I was wrong about the suspension being fully rebuilt on only one side, I had a closer look and it's just the LBJ on the driver side that's new. The upper ball joints on both sides are toasted too so now priority is just replace all the ball joints and bushings. I had a look through my big stack of invoices and it looks like the outer tie rods are fairly new though. I also checked out the PCV valve and it looks like it might have been replaced at some point because it does not look OEM. So, new ball joints and bushings it is.
Old 09-12-2021, 01:19 AM #22
Originally Posted by spartacus View Post
Cleaning the battery terminals...
I should not have brushed off this advice so dismissively. I had to get jumpstarted when I left work today and on the drive back I was getting power fluctuations whenever I would brake. I get home and clean the battery terminals immediately, car goes back to normal. Keep your battery terminals clean people!
Old 09-12-2021, 07:04 AM #23
Brian.'s Avatar
Brian.'s Avatar
Clean the OTHER ends too, body ground and engine ground were both issues on mine. I ended up doing a partial "Big 3" with stuff I had on hand, which resolved a number of niggling issues (like, the power seats wouldn't work unless the engine was turning over... was something that constantly annoyed as my wife is 5'4 and I'm 6'4)
4runner , check , daily , module , shipping
Daily Driver 3RZ 4Runner Build UnderFire 3rd gen T4Rs 453 01-11-2020 03:12 AM
Is the 4Runner your toy or daily driver? Bumbo 4th Gen T4Rs 23 12-12-2016 11:18 PM
WTB 1st gen 4runner (daily driver) alexgvojic Classifieds - buy & sell (no commercial ads please) 0 05-06-2009 01:26 PM
Is the 4Runner your daily driver? jwa898 4th Gen T4Rs 92 05-23-2008 07:54 AM
