Old 09-27-2021, 09:34 AM #31
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Originally Posted by repo View Post
E-rated tires are brutal at low speed if not aired down. At 40psi it feels like no suspension at all unless driving at speed on the road. 20-30 feels totally different but you cant drive on the road like that. Even 32psi is on the edge of where you start overheating E tires on the road.
I’ve yet to get my tires hot doing 60-65 mph at 20 psi. I try to keep it under 60 mph.
I check them religiously, they’ve never been warm even a little bit yet.
I obviously can’t speak to any other tire situation is, but these Kanatis have been pretty great against heat.
You got to air those tires down for sure to do anything with them otherwise the traction and the ride quality suffers tremendously. I picked up a portable viair portable 400p rv compressor just to keep my truck since I like having portable air in my 4runner so much. It’s a little slower than the big twin ARB. I still go from 20 to 40 psi in about 3 minutes though. For wheeling airing down just simply cannot be beat. It changes the experience entirely in my opinion.
But yeah, unless you’re trashing on the tires, I don’t know if I would recommend an E tire. I think unless you’re doing a lot of regular off-roadin, just get a C rated tire and take it a little bit easier while you’re Aired down also.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 09:40 AM #32
Romeo1's Avatar
Romeo1's Avatar
From the ARB application guide.
Old 09-27-2021, 10:39 AM #33
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
I have the same VIAIR it's great. According to this 44psi in E tires is equivalent to 32psi in a P tires. But it feels much worse driving on anything other than smooth pavement with E tires at 44 psi. I seem to get LESS traction on road under 40psi.
LT tires need more air pressure.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 07:14 PM #34
Roc Doc's Avatar
Roc Doc Roc Doc is offline
Roc Doc is on a distinguished road
Roc Doc's Avatar
I have Kings in the front of my 98, and the PO installed spacers in the back and some Skyjacker or other generic white can shock. I installed the Toytec Superflex springs and they were too tall and the spring rate was too low and it made the Runner not sit level and it was too floppy even with both anti-roll bars connected.
I replaced the Toytec springs with OME 2906 springs and OME 60073 shocks and it's worlds better and I didn't have to drop a grand. I also have extended anti-roll bar links, SCS F5 (as light as they come), wheels and D rated Nittos, so my unsprung weight is also helping. This combo works great and I have yet to bottom out either the front or rear.
1998 4Runner Limited, King coilovers, Trick Toys Fab front bumperette/lightbar, TTF rock rails, Toyo 265's, locker mod.
Roc Doc is offline   Reply With QuoteReply With Quote
Old 09-28-2021, 09:52 PM #35
Romeo1's Avatar
Romeo1's Avatar
I haven’t noticed a traction difference on the road above 35psi. What I do notice though is the vehicle struggles to get to above 70mph foe the interstate when 35 or below. 36 psi and things start working right at high speed. 38 it gets happy. 40psi makes it feel practically normal. Relative to a stockish tire.
Now, it’s obvious the rig has LTE tires when I drive it. I wish someone made an aggressive AT/MT tire in C, 3ply side wall, and 3PMSF rating. That combo just seems to be such a unicorn. Man that would be awesome. It’d be like adding 20 horsepower at least to the feel of it.
Maybe I should contact the tire companies. I made some suggestions to On X and they incorporated them in the last update. Best "good-enough" shocks for 890s?
Old 09-29-2021, 06:23 AM #36
Duratracs are available in C for 265/75/16. I dont think there's any options for 285 unless you go to 17" wheels. I have fairly worn out KO2s and the tires squeel under about 38 psi, it's counter-intuitive but I'm guessing there's not enough weight on them from the 4runner to grip properly. But over 40psi they start to get harsh and feel sort of "glidy" if you know what I mean and I don't quite trust them. There seems to be a pretty narrow sweet spot for the psi.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 09-29-2021, 09:22 AM #37
Romeo1's Avatar
Romeo1's Avatar
The Dura track would be perfect if it was a three ply sidewall…… trust me, I checked, like read the side of the tire checked.
In fact, the tires I currently have really look like a Duratrac knock off design.
I agree what you’re saying about the sweet spot, it does seem to be a pretty narrow window. I’m sure it totally has to do with the fact that those tires are not really designed for a vehicle this light.
Old 09-29-2021, 10:27 AM #38
By 3-ply you mean SL rated? The Wildpeaks are available in SL. Duratracs 265s come in C which is supposed to be 6-ply equivalent (product 312018027). And E 10-ply equivalent (product 312034142). Dunno how much difference would be felt between C and E it seems to be personal perception. I'll tell you those E KO2s are damn indestructible and the tread lasts for ages. They get progressively more pretty terrible the wet conditioned though, to the point I use 4hi when it rains hard.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 09-29-2021, 04:09 PM #39
Romeo1's Avatar
Romeo1's Avatar
No no no. The sidewall plies. Even the BF Goodrich KO2s only come in a 2 ply sidewall in load C. You have to step up to a load D or E for the 3 ply sidewall.
SL rated tires are for the pavement queens. Damn I hate the SL rated tires on my work tundra truck. They’re great for fuel economy and all, but it feels like they are just looking for a place to go flat.
890s , bump , cheap , explode , shocks
OME 890s vs ToyTec 3" rear coils thezentree 3rd gen T4Rs 16 08-01-2020 01:47 AM
WTT: Ome 890s for 2" springs PCF4runner For Sale: Suspension/Wheels/Tires 1 01-31-2017 02:45 PM
Any good "Snake Oil" remedy for a tiny rear main leak? dgoll75 3rd gen T4Rs 7 02-01-2015 04:09 PM
FS: 3rd gen 890s, stock struts with 2" spacers - PA $150 bfett22 For Sale: Suspension/Wheels/Tires 7 08-06-2014 06:34 AM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
