Old 10-04-2021, 09:00 AM #16
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Originally Posted by Pyral View Post
I got around to removing the exhaust manifold heat shield, to anyone reading this in the future removing the bolts for the shield is a lot easier than you might expect, even if they are rusty like mine were.
I found what I believe to be a hairline crack between cylinder 2 and 3.
Photo 1 (as close up as I could get)
Photo 2 (more complete photo of the crack)
Photo 3 (close up of crack from different angle)
Photo 4 (zoomed out to provide orientation in engine bay)
Link to complete album
Is this a large enough crack to be the source of my engine tick?
The 3RZ engines are known for cracked exhaust manifolds. Mine was replaced by the dealer and PO when it had ~150k on it. I proactively replaced that one with the OEM mini-header which has been working great for years now.
That crack will definitely be audible.
JZiggy is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 11:31 AM #17
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Here is a video of the exhaust leak. Now to replace the manifold. I've read that this fix can have a small improvement in power, is that true?
Do I have to replace the heat shield when I fit the miniheader or can I reuse the old one even though its larger?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 10-04-2021, 11:44 AM #18
JZiggy's Avatar
JZiggy's Avatar
The miniheader heat shield is different. You can:
- Buy a new OEM one
- Hack your old one to fit
- Run without, probably not a big deal (though I'm too OCD to do it that way)
Hopefully you found Timmy's video where we did this mod?
Old 10-04-2021, 12:17 PM #19
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Yep, I've seen the video Timmy did for this issue. I'm using the part numbers from it. From a cursory search that manifold (17141-75080) costs $254 from camelback Toyota. The manifold and heatshield are far from the only parts that will need to be purchased.
3rz , engine , tick , ticking , video
what is this engine tick/clunk? Lamer 3rd gen T4Rs 18 12-31-2018 10:58 AM
Engine tick Morania 3rd gen T4Rs 10 06-13-2016 10:17 AM
Ran engine dry. Now valve tick clown baby 3rd gen T4Rs 12 04-24-2014 01:46 AM
Engine Tick Billyinatree 4th Gen T4Rs 2 05-24-2010 03:10 PM
4.7 V8 Engine Tick inscarguy 4th Gen T4Rs 8 05-07-2010 03:03 AM
