Old 09-11-2021, 03:25 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
3RZ Engine Tick
My 3rz has a noticeable engine tick. The ticking happens at all RPMs whether my engine is warm or cold. The fact the engine was cold in this video doesn't matter at all, it would sound the same if it had fully warmed up.
(Link if this is broken)
I shot a video from inside the cabin of the engine sound. I usually drive more leisurely and smoothly than how I did in the video, but I wanted the full range of gears that I could get in a short time. I'll try to make another one from the engine bay later on. The ticking is most noticeable 27 seconds into the video after I made that sloppy shift.
I've had this ticking for a while, but I didn't think much of it until I heard another 3rz without such a pronounced tick.
I know that the 3rz-fe suffers from valve clearance issues. They can make a ticking noise if they get too loose. But I can't find a video of what that sounds like.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 09-11-2021, 03:43 PM #2
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
My first action would be to pull off the valve covers and perform a quick valve adjustment.
2000 4Runner Limited 4x4 V6
Old 09-11-2021, 07:15 PM #3
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
+1
Sounds like valves need adjusted. Timmy and I did a video on it. Let me know if you need some help… it’s not too hard once you get your head around it.
JZiggy is offline   Reply With QuoteReply With Quote
Old 09-12-2021, 05:25 AM #4
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I understand the idea behind it. From what I understand having the valves too loose isn't destructive in most cases (it would have to be really extreme), it will mainly decrease power and efficiency.
I might wait a month or two because my current schedule is too busy to have my only car out of commission waiting for a shim.
How do you check the timing chain tensioners while you do this job? It was mentioned in timmy's video, and I would like to know how much life there is on it.
Old 09-13-2021, 01:27 AM #5
jth32199's Avatar
jth32199 jth32199 is offline
Real Name: Jacob
jth32199 is on a distinguished road
jth32199's Avatar
Real Name: Jacob
So I have a 3rz and been getting through the noises it makes. I was getting a ticking and it sounded like it was coming from the motor but it ended up being an exhaust leak which is easy enough to find. The 3rz's with the cast exhaust manifold are known to crack and have a leak. Also I had a clicking/ticking noise and it turned out to be the u joint closest to the transmission/transfer case.
Do you here it coming from the passenger side of the vehicle? Does it happen on when you're moving or both when you're moving and parked?
It could also be a U joint going out or in need of some grease. Let me know!!
Sent from my SM-G986U using Tapatalk
jth32199 is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 05:46 AM #6
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I recently got all the zerks greased for an unrelated rotational squeak that I was having(which didn't fix it). So my u joints are all looked after, and they showed signs that the previous owners also greased everything regularly too.
A manifold leak is possible, but very unlikely. My whole exhaust system is crusty, but my car passed CA smog in 2020, they would of been all over me if there was some sort of leak. And the tick was present even then, luckily it didn't keep me from passing.
The noise is present even at idle.
Old 09-13-2021, 08:17 AM #7
JZiggy's Avatar
JZiggy's Avatar
If it's a cracked exhaust manifold (which does happen on the 3RZ) the sound will be very clearly load-dependent. Valvetrain noise is usually just RPM dependent.
Old 09-13-2021, 03:14 PM #8
jth32199's Avatar
Real Name: Jacob
jth32199's Avatar
Real Name: Jacob
You know what, you're completely right. I know the 3rz's have to get valve adjustments more frequently than the 5vz.
Old 09-13-2021, 03:15 PM #9
jth32199's Avatar
Real Name: Jacob
jth32199's Avatar
Real Name: Jacob
I gotcha, mine passed smog here in Comiefornia twice, maybe I got lucky 3RZ Engine Tick
Old 09-13-2021, 04:27 PM #10
davidch davidch is offline
davidch will become famous soon enough
I would suggest exhaust leak. I own two (his and hers) 3RZ-FE 4Runners. One had a cracked exhaust manifold at 120k.
Cracked headers are not an uncommon issue with this engine. Apparently, Mighty Toyota itself determined the cast manifold had problems, as later Tacomas had a header-style manifold. See posts here:
any good source for a 1999 tacoma exhaust manifold? | Tacoma World
Assuming you can get the 2 nuts and 2 bolts off the manifold shield, it's quick and easy to check.
In my experience with 5 such engines - others will disagree - these engines exclusively suffer decreasing valve train lash, which doesn't lead to a ticking noise.
davidch is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 06:20 PM #11
JZiggy's Avatar
JZiggy's Avatar
The header is a great upgrade. Timmy did a video on that too using my truck.
You are correct on valve lash. They tighten.
Old 09-13-2021, 08:52 PM #12
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
The only thing I can think is that the previous long time owner intentionally set the valves loose so they could have more time between adjustments. I talked to a Toyota mechanic who said the same thing about the valve clearences getting tighter not looser. I'll probably get the valves done no matter what sense I don't know when they were done.
I shot a video from the engine bay today. At idle the tick was hard to decern, especially through video. And it does become more apparent under load. I thought exhaust leaks typically made the vehicle louder. If its not the valves its probably a cracked manifold.
Old 09-14-2021, 02:33 AM #13
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I got a video in the engine bay. It isn't going to be very helpful because my phone did a poor job of picking up on the sound. Make sure your sound is down, I didn't realize I had the phone mic pointed in a draft created by the engine for a part of the video.
I think the engine ticks more under load then at idle so that might be the reason it isn't as apparent in this video.
I'll try to remove the shield, but there is a good chance the bolts wont come loose without more violent extraction methods. My vehicle is a 49 state vehicle, so I would think that it would already be at a disadvantage when it went through CA smog.
Old 10-04-2021, 03:02 AM #14
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Could this be the culprit?
I got around to removing the exhaust manifold heat shield, to anyone reading this in the future removing the bolts for the shield is a lot easier than you might expect, even if they are rusty like mine were.
I found what I believe to be a hairline crack between cylinder 2 and 3.
Photo 1(as close up as I could get)
Photo 2(more complete photo of the crack)
Photo 3(close up of crack from different angle)
Photo 4(zoomed out to provide orientation in engine bay)
Link to complete album
Is this a large enough crack to be the source of my engine tick?
Last edited by Pyral; 05-16-2023 at 02:26 AM. Reason: Maintaining photos (linkrot) and formatting improvements
Old 10-04-2021, 05:49 AM #15
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
I'm seeing evidence of exhaust gas staining the metal, which
is, yeah, you'll probably hear it. Gotta be changed out anyway,
won't fix itself
Also looks to me like there might be a second crack in photo 1,
north of the first one.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
3rz , engine , tick , ticking , video
what is this engine tick/clunk? Lamer 3rd gen T4Rs 18 12-31-2018 10:58 AM
Engine tick Morania 3rd gen T4Rs 10 06-13-2016 10:17 AM
Ran engine dry. Now valve tick clown baby 3rd gen T4Rs 12 04-24-2014 01:46 AM
Engine Tick Billyinatree 4th Gen T4Rs 2 05-24-2010 03:10 PM
4.7 V8 Engine Tick inscarguy 4th Gen T4Rs 8 05-07-2010 03:03 AM
