Old 09-12-2021, 11:19 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
What fuse should I use for H7 fog lights
The positive terminal on my fog lights came off and I'm going to wire it to the fuse box rather than to the battery.
I might use the abs fuse location (I don't have abs), or one of the blank positions if they are wired in.
I have a fuse tap but I don't know what fuse size is ideal. The H7 are 55 watt/ 12V and there is 2 of them.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 12:12 AM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
Each bulb is going to draw ~4.6amps, with a 20% safety factor, you are looking at 11amps which means a 15 amp fuse. That said, the fuse is protecting the wiring from damage which could lead to an electrical fire, so make sure that your wire gauge is appropriate for that load or you could have an electrical fire at a load which won't blow the fuse. Given the load you are looking at, I'd want to use 12 gauge wiring for that, but depending on which chart you are looking at you will find some that say 14 gauge is safe for shorter runs.
Skulking is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 05:30 AM #3
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Turns out the owner had added some safety. Like the speakers, they wired in a fuse by basically wrapping the wires around the legs of a fuse and mummifying it in electrical tape. Fuse value? 20 amps- nope, 25 amps? Higher still. They used a 30 amp fuse.
I wanted to use one of the blank spots in the fuse box, however Toyota didn't put metal contacts for them. How can I bring power to one of the blank spots in the fuse box?
Old 09-13-2021, 11:33 AM #4
spartacus's Avatar
spartacus's Avatar
You'll have to pull the fuse box up and add a pigtail of appropriate gauge with a female contact connector from the buss bar to the slot then run a wire from thee to the to the accessoriy. I am not sure what size.
@sleepydad has a great video showing the internals of the fuse box in later half of the following video.
https://www.youtube.com/watch?v=ZsRK8o5InIc&feature=youtu.be
abs , fog , fuse , lights , tap
Fuse for dash lights Woofer 5th gen T4Rs 4 07-18-2020 10:36 PM
LED grille lights - Add a fuse using the tail light / side marker fuse DigitalRJH 5th gen T4Rs 8 03-19-2019 04:44 PM
Which fuse is for the back-up lights? (lights not working) nalbertasr5 3rd gen T4Rs 2 02-07-2018 03:30 PM
Fuse for lights question GearJunkie88 5th gen T4Rs 9 01-05-2017 07:16 AM
Fuse for Brake Lights ilovemy4runner 4th Gen T4Rs 5 11-22-2010 03:22 AM
