Old 09-13-2021, 12:16 PM #1
potatofries potatofries is offline
potatofries is on a distinguished road
Suspension rubbing? Bottoming? Something else
A few months ago I installed the OME Stage 1 lift kit (881 front an 890 rear). After the lift I put on 265/75/16 KO2 tires, which is about 1" larger diameter than stock, and had it aligned at Toyota dealer.
All seemed fine for first 6 weeks or so.
But now the left front sounds like its rubbing or almost like it's bottoming out the suspension any time I go over small potholes, speed bumps etc. It's definitely not actually bottoming out and the ride is otherwise fine. We aren't talking off road here. Just small driveway potholes cause this. As does basically any parking lot speed bump, even at low speed.
It also doesn't appear to be rubbing. But that's just me looking for any signs there is rubbing in the wheel well area (ie areas that aren't dirty). It also has a sound more more similar to like an overloaded car bottoming out over a speed bump sort of thing.
It's just the left front that seems to be having this issue. Anyone had this before? My instinct was maybe the suspension settled a bit and the 1" larger tires were rubbing, but I don't see any evidence of rubbing. Last week I added the 5mm spacer that came with the kit, thinking if it was rubbing that started due to settling of the suspension, this extra 5mm would make a difference. But doesn't seem to have.
Anyone had this after an OME or other lift? Any ideas of things to look for?
'99 Toyota 4Runner Limited
'77 Volvo 242 DL
2011 Subaru WRX
potatofries is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 01:01 PM #2
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Originally Posted by potatofries View Post
265/75/16 KO2 tires
I think it’s unlikely tire rub. That size should be fine on all 3rd gens at stock height or taller. Not sure what it is, but I think you can probably rule that out.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 09-13-2021, 04:10 PM #3
Thanks. Yeah I'm with you there. I see no evidence anything is rubbing.
'77 Volvo 242 DL
2011 Subaru WRX
Old 09-13-2021, 05:42 PM #4
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Make sure your sway bar end links and brackets are tight.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 09:42 AM #5
Checked end links and brackets. One end link was slightly loose. Torqued to spec, but this hasn’t solved the issue.
'77 Volvo 242 DL
2011 Subaru WRX
bottoming , front , rubbing , speed , suspension
Rear bottoming out Brian1973 3rd gen T4Rs 19 03-21-2019 02:49 PM
275/70-17 Tires and 1.25 spacers....Any rubbing on stock suspension? cmilviper 5th gen T4Rs 7 10-15-2015 11:07 AM
Rubbing with FJC suspension and 265/70/17 tires? Nashvillerunner 4th Gen T4Rs 4 06-01-2010 10:37 PM
Bottoming out cruzmissile 4th Gen T4Rs 4 08-23-2005 11:23 AM
Bottoming out. I need advice. CardsFan Problems & Warranty Issues 2 07-19-2005 05:54 PM
