Old 09-16-2021, 11:31 AM #1
jonnyd42 jonnyd42 is offline
jonnyd42 is on a distinguished road
Imogene & Black Bear (colorado) in a stock 3rd gen?
I have a 2000 limited running Geolandar AT G015 265/75/16s. It has no lift & just the factory metal skid plates. It has an e-locker and currently still has factory running boards on.
My buddy just did this with no problems in a stock 100 series land cruiser, and another friend did it with zero problems in his 3rd gen with a ~2" lift.
Do you think I'd be able to navigate this in my car or would I need a lift to do it safely? Additionally, assuming it'll be problematic with running boards on, for breakover?
jonnyd42 is offline   Reply With QuoteReply With Quote
Old 09-16-2021, 04:20 PM #2
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
I can't answer for black bear but Imogene was very easy. if I can do it in a stock range rover, you can do it in a stock 3rd gen for sure. Just take the easy line and you should be fine.
Old 09-16-2021, 06:07 PM #3
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
Imogene probably has slightly more technical spots than Black Bear. One thing about BB is doing multi-point turns on the top couple of switchbacks. They're too tight for a 4Runner to make in one bite, they're steep, and there's a soft edge. So you'll need to be able to back uphill on an off camber diagonal situation. Since you have a locker, no real problem. But cars with poor articulation and no locker might have issues there, spinning,, and not able to make the turn.
Also, there's a trend of people rolling on a diagonal ledge above the 'notch' (a narrow shelf road that gets into the main downhill into Telluride). It's been slowly getting steeper over the years, and it's been catching people out who try to drive straight over it, the downhill tilt is more than it appears, and it can certainly tip you. Hang right, then turn sharply down it.
JohnMc is offline   Reply With QuoteReply With Quote
Old 09-16-2021, 06:28 PM #4
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Originally Posted by JohnMc View Post
Imogene probably has slightly more technical spots than Black Bear. One thing about BB is doing multi-point turns on the top couple of switchbacks. They're too tight for a 4Runner to make in one bit, they're steep, and there's a soft edge. So you'll need to be able to back uphill on an off camber diagonal situation. Since you have a locker, no real problem. But cars with poor articulation and no locker might have issues there, spinning,, and not able to make the turn.
Never wheeled in CO and even I have seen the vids of tipping on that particular ledge. It's funny, I had even made a mental note to Hang right, then turn sharply down it just like you, with the real knowledge, said. Hopefully I'll put it to use one of these days.
Old 09-16-2021, 07:20 PM #5
spartacus's Avatar
spartacus's Avatar
In my opinion, try to find someone in town that has done it and follow them. your 3rd Gen is capable to do BB and Imogene. If youvé been off roadin high montain off camber narrow roads before you'll be fine.
Old 09-16-2021, 11:44 PM #6
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
I did Black Bear, Imogene, and many other trails in the area many times, in my 3rd gen. It was a V6, 5-speed, with the rear diff locker. The only non-stock addition as far as increased wheeling ability, was 1" larger LT 265/75R16 tires.
The trails aren't difficult. There's a pucker factor on Black Bear, and knowing how to choose a line is important.
The San Juans are beautiful.
02SE is offline   Reply With QuoteReply With Quote
boards , factory , lift , problems , running
Black Bear Pass Co TucsonMike 3rd gen T4Rs 10 08-17-2021 04:55 PM
Black Bear Pass? Hardrunner 5th gen T4Rs 36 07-28-2017 10:25 PM
Black Bear and Imogene Pass in an open diff 3rd gen? wake_rider 3rd gen T4Rs 30 07-18-2016 10:08 AM
Black Bear-Imogene Labor Day weekend. BOVADS Off-Roading 3 07-22-2015 04:47 PM
Black Bear Road, CO Paul2660 Off-Roading 8 08-16-2007 08:26 AM
