Old 09-20-2021, 02:53 PM #46
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Originally Posted by Endlessblockades View Post
Yep - I just went down a rabbit hole on the 2000 vintage 4Runners. Moral of the story: don't lose both transponder keys!
That can be recovered from.... I only had 1 "sub" key, now have 2 master and 1 sub. Cost me under $100 (including key cutting, but my dealer did cut 3 for $0). Steep learning curve, but it's doable by anyone at home if they put in the effort.
Toyota did *NOT* make it easy though. My solution was very much a hack approach. I think a good locksmith could do the same work with some tech tools for under the $1000 Toyota wants for a new body ECU.
Brian. is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 02:56 PM #47
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Originally Posted by fourfive View Post
Speaking of GPS, I recently got one from my friend that was previously on one of his supras that he just sold. I haven't looked into the different options on the market, mainly because it was free, but he seemed to like it based on the cost & functionality. The company is called Bouncie. I haven't gone through the subscription process yet so I don't have any personal feedback on it.
I am also interested in what people are doing RE: GPS and I think I read that with Bouncie 'the 'OBD' port is used? Is that an under-hood diags port? If it's the 'OBDII' port under the dash that's not going to work for me as I have an ultra gauge there already and that spot seems like it's too easy for a thief to find and toss out the window.
"Compared to similar OBD-port GPS car trackers, Bouncie falls in the middle range when it comes to price. It strikes a good balance between its competitors with a slightly higher initial device cost but no activation fee, a low monthly subscription fee, and no long-term contracts.Sep 18, 2020"
Nevermind - it uses the OBDII port. I think I will need to look more into a Spy on your Spouse version than a Fleet-Management GPS solution.
Old 09-20-2021, 04:22 PM #48
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
I am also interested in what people are doing RE: GPS and I think I read that with Bouncie 'the 'ODB' port is used? Is that an under-hood diags port? If it's the 'OBDII' port under the dash that's not going to work for me as I have an ultra gauge there already and that spot seems like it's too easy for a thief to find and toss out the window.
It does use the OBDII port. You bring up some good points. I know that my friend I got this from used it to keep track of a few cars he rented out on Turo. Since this was a recent gift I haven't really looked into it or other GPS options. I keep my scangauge plugged in while I drive and would probably just swap the 2 when I'm not driving. From my very limited knowledge on the different options it seems like there are trade offs on how/where they install & no doubt the OBDII ones will be easier to install & remove which would defeat the purpose if the primary objective was to be discrete.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 11:20 PM #49
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
hope you find it, that's a sick rig, i hope you get it back!
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 07:18 PM #50
WeAreSLO WeAreSLO is offline
WeAreSLO is on a distinguished road
Originally Posted by 4Reak Show View Post
My opinion is the ground wire for the EFI relay coil (control) side. This ensures the computer is totally offline. I’ve considered the starter relay as well but then if it’s a manual, it could be push started. EFI relay off line, it can crank all day long: no injectors, no spark, no fuel pump.
I have a kill switch hidden in the interior that disconnects power to the fuel pump. Very simple to install and great peace of mind. I had a 1994 Honda Accord stolen from me back in 2008 so I'm a little sensitive to auto thefts.
WeAreSLO is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 07:52 PM #51
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 is a jewel in the rough cblock406 is a jewel in the rough cblock406 is a jewel in the rough
cblock406's Avatar
My heart goes out to you. My 4runner was stolen in Washington about 5 years ago. I thought I would never see it again, and two weeks later I got a phone call from the police letting me know they recovered it.
I have some documentation in my build thread; basically a couple tweakers lived in it and completely trashed the inside, but mechanically didn't do any damage. It took a good while to get it back to "pre-stolen" condition.
Fingers crossed you get yours back in as least the same condition or better as I got mine. That's a great looking 4runner. Hopefully this will just be another good story about your awesome 4runner in another 5 years.
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 10:12 AM #52
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
Originally Posted by T4topher View Post
I bought it when I was going to trade school in Sacramento, someone broke into my Tacoma in my motel parking lot and stole a north face jacket a back pack with some school books and my spare key lol…
Unlocked
Locked
Installed
Ahhhhu yes! That looks familiar. I think I’ve seen something similar before. Looks really stout and reliable. Thanks for sharing that! Might look into getting one.
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 05:10 PM #53
DenverAirport's Avatar
DenverAirport DenverAirport is offline
DenverAirport will become famous soon enough
My 4runner has been found.
The person who was caught with my car was taking off the roof rack early in the morning today...Huge thanks to everyone who shared / posted pics and to everyone who has given me big advice moving forward.
Insurance inspection begins tomorrow or Tuesday then I'll get to see it again. Very stoked.
99' SR5 "Highlander Edition" - 301k - 4WD, Factory rear locker, 2.5" Dobinsons IMS lift, SPC UCAs, CJV 9168 TR axles, 199mm TBU, Tom Wood's driveshaft, eimkeith PCK, Aluminum Koyorad, Ultragauge
97' Limited - 250k - Stolen & Found (and Sold) - 4WD, 3" Billstein 5100 lift with OME 881, 890 springs, Diff drop, Camburg UCA's, 231mm TBU, Tom Wood's driveshaft, eimkeith PCK, Champion radiator, Ultraguage
DenverAirport is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 06:28 PM #54
Brian.'s Avatar
Brian.'s Avatar
That's outstanding news! Hope it's at least Mostly unmolested (parts missing are easy to replace).
Old 09-26-2021, 06:43 PM #55
Hoping they did serious damage to my LCA's somehow so my insurance has to pay for me to replace them (all so I don't have to replace the bushings myself.)
Old 09-26-2021, 06:49 PM #56
Real Name: Blair
Real Name: Blair
YES!!! That's great news
Old 09-26-2021, 09:19 PM #57
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
Great news indeed!!
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 09-26-2021, 11:21 PM #58
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
Good news! Make sure you get compensated for the lost value of the vehicle showing stolen, the miles and wear they drove, damage they caused, money you spent on rentals, and a professional cleaning. Who knows what they had in there...
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Unner is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 10:25 AM #59
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough TheSaturnV will become famous soon enough
There are special sections in hell set aside for thieves and short-wire electricians.
"Not everyone is cut out to be a 3rd Gen owner."
2000 Black LTD with ELOCKER, almost 100% stock
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 04:02 PM #60
Greenly 555 wire stretcher.
4runner , mechanics , mount , roof , truck
Stolen, Recovered in bad shape wcjeep Off Topic 3 11-22-2019 10:03 AM
Any one had their front seats recovered? dclark2171 5th gen T4Rs 12 01-27-2018 01:46 PM
Has anyone had their leather seats recovered? dclark2171 5th gen T4Rs 2 01-20-2018 11:32 PM
BASC Driver seat recovered Bigmd 3rd gen T4Rs 12 07-02-2016 02:39 PM
Recovered 2004 Cracked Dashboard kylebacc 4th Gen T4Rs 0 12-07-2012 01:27 PM
