Old 09-19-2021, 10:36 PM #1
beingnotdoing beingnotdoing is offline
beingnotdoing is on a distinguished road
Transfer case model number
Okay, time to test your 4Runner knowledge.
Engine model: 5VZ-FE
Transmission model (automatic): A340F
Transfer case model: ???
What is the model number for a 3rd gen transfer case? Am I just assuming incorrectly that they have a model number?
beingnotdoing is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 03:02 PM #2
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
The transfer case of 3rd gen 4runners are either VF2A which is the standard transfer case (I believe including all the electronic actuating versions), or VF3AM which is the multi-mode (locking center differential) found in 99-00 Limited models and all 4WD models 01-02.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 09-20-2021, 03:03 PM #3
Team_Jake's Avatar
Team_Jake's Avatar
And for anyone wanting breakdown of Toyota powertrain naming
Engine Model 5VZ-FE
5 = The 5th generation of the Toyota VZ engine family
VZ = A family of Toyota V6 gasoline engines designed for low-mid range power and torque
F = Normal/standard cylinder head, double over-head cam
E = Multi-point fuel injection
Engine Model 3RZ-FE
3 = The 3rd generation of the Toyota RZ engine family
RZ = A family of Toyota I4 gasoline engines (which replaced the long running R family)
Transmission Model A340E & A340F
A = A family of automatic transmissions built by Aisin-Warner
3 = The 3rd generation of the "newer" (3-digit) transmissions in the A family
4 = 4-speed
0 = Application designation, 0 is earliest designation
E = Electric control (or 2WD)
F = 4WD
Transmission Model R150 & R150F
R = A family of manual transmissions built by Aisin-Warner
1 = The 1st generation transmission of the R family
5 = 5-speed
F = 4WD
Transmission Model W59
*An older 2 digit naming designation as opposed to 3 digits after the family name*
W = A family of manual transmissions built by Aisin-Warner normally associated with I4 engines
5 = 5th generation of the W transmission family
9 = Application designation
Transfer Case Model VF2A & VF3AM
VF = Family of Toyota transfer cases with a chain driven front output
2 = 2nd generation
3 = 3rd generation
A = Part-time 4WD
M = Multi-Mode
Old 09-21-2021, 02:34 AM #4
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
A = part-time 4WD (Multi-Mode 4WD)
B = full-time 4WD (the one used in the 95-series prado)
2 = 2nd generation
3 = 3rd generation
A = ?
M = Multi-mode?
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 09-21-2021, 12:32 PM #5
Team_Jake's Avatar
Team_Jake's Avatar
Nice! Edited
Old 09-26-2021, 04:32 AM #6
Thumbs up
Awesome!
Not only did you know the model names of all the drivetrain components, but you know the breakdown of the codes themselves. Thank you both. I stand in awe of your massive brains.
Old 09-26-2021, 04:44 AM #7
All of this reminded me of a website I used like a decoder ring for figuring out my differential gear ratio in preparation for doing a factory e-locker swap. I thought it would be nice to sort of close the loop on this drivetrain model number love-fest by including a link to the website that has all of the codes explained:
off-road.com
You can find your code on the VIN plate on the door sill (e.g., A03A) and go to town.
Old 01-02-2023, 11:53 AM #8
TimOC TimOC is offline
TimOC is on a distinguished road
Follow-up Question
Can a VF2A TC from a 6 cyl AT be installed on a 6 cyl Manual Transmission (2000 SR5), without any modifications ?
TimOC is offline   Reply With QuoteReply With Quote
Old 01-02-2023, 12:32 PM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
The only difference between the two is the transfer case shift lever is a different shape. On automatic transmissions the shift lever goes towards the left, and on manual transmissions the shift lever goes to the right. The transfer case shift levers will interchange between the two.
Old 01-03-2023, 10:44 AM #10
Thank you so very much!
case , incorrectly , model , number , transfer
Please help me figure out my transfer case model Forgetful 3rd gen T4Rs 7 01-04-2023 07:56 PM
Transfer Case Pictures (and model numbers?) aykalper 3rd gen T4Rs 0 11-14-2018 09:42 AM
what kind (model) transfer case in the 5speed 3rd gen (2000) cordrayj1 3rd gen T4Rs 3 11-03-2011 04:06 PM
